2017 Turtleback Expedition
j556ram
For Sale
2017 Turtleback Expedition Trailer is looking for a new home.
Our little trailer is sitting in our garage not having as much fun as it could be and deserves better. It has served us well,
always cared for and always garaged. All good things to say about the trailer and the Turtleback family.
I am very impressed by it and its incredible function and performance.
The trailer has a custom roof rack and allows it to fit inside a regular 7 foot garage door. No need to store it outside.
I bought this trailer used in 2020 and it’s been taking care of us ever since.
This trailer is 100% optioned out. It’s fully loaded, including the following options:
- Icon Suspension and Wheels with matching spare on BFG K02 in 285/70/17 with plenty of life
- Max coupler articulating hitch, 6000lb rated
- Dual battery electrical system with Blue Sea marine grade components, dual AGM
deep cycle batteries for combined 210 amp hours of power, Blue Sea 8 circuit
fuse box, Blue Sea dual battery disconnect and Blue Sea M2 c
harge monitor
- 2000 Watt PROwatt SW Inverter
- ProMariner ProSport 6 battery charger (can plug trailer into AC outlet)
- REDARC BCDC1225D Solar and DC to DC charger
- Upgraded Expedition composite kitchen and interior panel upgrade (marine grade high
density polymer material, waterproof and UV stable)
- Turtleback fridge slide
- Turtleback shower awning bracket with privacy shower
- Rear awning to cover kitchen area
- RotopaX (2 gasoline 4 gallon each)
- Accessory propane tank
- ARB 8 x 8 awning with attachable walls and floor
- Rear 4 x 4 awning for the kitchen
- iKamper Skycamp (Gen 1) still in great shape with removable annex room and shoe rack
and probably more features I forgot to mention.
Base construction:
Dimensions: 150" length x 78" width and 80" at the highest point of the iKamper RTT
Weight: approximately 2600lbs with a GVWR of 3500lbs
- chassis: welded 2 x 3 galvanized tube steel chassis with 11 g aluminum floor system
- 2 inch hitch receivers, front and rear
- Expedition trailer aluminum skin and box including front, 45" side boxes, 31" nose box,
and turtle tailgate emblem
- slide out kitchen including partner steel stainless stove with dual 10000 btu 18" burners,
Dometic deep well stainless steel sink and faucet with tempered glass lid
- onboard systems control panel (blue sea circuit breaker panel, battery power disconnect,
USB/12v chargers, voltmeter, water heater switch, exterior and interior lighting controls
- 7 pin trailer connection
- dual stainless steel fold down prep tables, 18" x 36" on tailgate swing, 16" x 25" prep table
on kitchen door
- 42 gallon water tank with water pump
- Dometic on demand 6 gallon water heater
- lockable shower door with shower handle control and shower hose and head
- Primary propane tank (11lb)
- Tailgate with spare mount and RotopaX mount
- Nose jack 2000lb swing away tongue tack
- Safety systems: trailer break-away brake activation switch, dual towing safety chains
Title in hand. Just renewed the DMV PTI in September 2024
Listing for sale at $20K OBO.
Located in Orange County California
j556ramirez@gmail.com
Joe Ramirez
  • Like
Reactions: Eph
2eleven
