2018 Four Wheel Camper (FWC) Hawk and 2012 Toyota Tundra Double Cab SR5
Up for sale is our 2018 Four Wheel Camper (FWC) Hawk Camper and 2012 Toyota Tundra Double Cab SR5. $41,000 Combined. $25k for camper, $16k for truck. Located near Denver, CO
This truck and camper has served our family well on road trips exploring Colorado but it is time to find something bigger for our growing family.
Everything works 100% in the camper and there is nothing in need of repair.
The tundra has 120k miles and is in great condition. The truck has a long history of regular maintenance on its carfax report, and we have continued that regularity since we took ownership. I have all receipts
Camper:
- Original Owner
- 2018 Four Wheel Camper (FWC) Hawk
- Side Dinette model
- 6” Memory Foam Mattress topper
- Queen Size bed
- Chocolate Brown Fabric
- 100 Watt Roof mounted solar
- Yakima Roof Rack (Jet stream bars)
- 85 Liter Fridge (12v)
- Forced Air Furnace (Serviced in 2022 with new motherboard installed).
- 6 Gallon water heater with outside shower (Serviced in 2022)
- 2 roof vents with powered fans
- 8’ Side Awning
- Yakima Roof Tracks for additional mounts
- Rear Flood lights - LED
- Thermal Pack
- 2 AGM Batteries (Excellent Condition)
- Flush mount sink and stove
- 4 Jacks Included
- Carpet
- There are no leaks nor has there ever been any.
Maintenance:
- Rear door window re-sealed
- New water tap on exterior
- New motherboard in furnace
- Water heater serviced in 2022
- The gas strut roof lift assists are showing some age (some rust) but are working 100%, may need replacement down the road
- Minor scratches and scuffs over the years, nothing that I would consider an eye sore. Exterior is similar.
Tundra:
- 2nd owner
- Clean title, no lien
- No oil leaks
- TRD Rear Sway Bar
- Front and Rear 2” Hitch receiver. Really nice for extra gear.
- OEM Shocks/Leafs (good condition)
- Firestone Airbags with ports in rear of truck
- Goodyear Wrangler Duratrac E - Rated tires, 7000 miles on them, excellent tread life
- Upgraded headlight bulbs
- 4WD and transmission are excellent, the shifting is crisp, and 2WD -> 4WD is very smooth.
- Exhaust in good condition
- Perfect alignment
- Tinted windows
Maintenance:
- New Radiator at 110k
- A/C Serviced at 110k
- Alignment at 110k
- Brake Service at 100k
- Valve cover gasket replaced at 95k
- Coolant lines replaced at 95k
- Spare tire hoist system replaced at 95k
- Front differential fluid service at 90k
- Rear differential fluid service at 90k
- Transfer case fluid service at 90k
- Power Steering Flush at 90k
- Driveshaft torqued and lubed at 90k
- Synthetic oil changes serviced at Mountain States Toyota Dealer & Fine Tuned Automative
- All filters replaced on schedule
- The floor/feet vents for heating/cooling do not work. However, air flows great through all other vents and defrost.
- A stain on rear seats, about 2.5” wide
- A small chip out of the center console arm wrest, about 0.5”
- Minor scratches and scuffs you’d find on a 13 yr old truck, but nothing is an eye sore, it looks great overall.
- 2 of the wheels have small 1” paint chips where the powder coating came off
Vehicle has a reported collision but the damage was extremely minor, to the tune of $1500 and I have the receipts. The damage was to the rear fender, it has been repaired flawlessly. There are zero signs of any repair.
Wolfbox
