2018 Specialized Fuse XXL custom build, Columbus, OH 43228, only for the big guys....
bouncer
posting for sale from a militant non smoker home a used but mint condition hyper gloss Fuse (Part No. 129201, color code 240177) which is completely custom built except for the headset.
This bike gets hand washed, polished and waxed on a regular basis. yes, even the spokes have a coat of wax on them.
the bike was purchased at BikeSource on Feb 19th, 2018 - the frame was immediately stripped down after purchase and all parts sold, so they are no longer available.
If you are a tall / husky rider - this bike is set up for you and can be ridden properly on day one.
I am >6'5" and ~300 lbs.
if you are as well you will know the struggle of finding a bike you can fit on that just works.
This bike has taken me to the next level and has performed flawlessly at some of the most fun trails across the country.
The summer of Covid i was lucky enough to be able to ride out west - everything from Phil's World in Cortez, CO to part of The Whole Enchilada in Moab, UT.
The bike performed flawlessly.
Do not hesitate to contact me if you have any questions -
the only reason I am attempting to sell it is because I have purchased a full suspension stumpjumper evo and even though i could keep it,
switching in between the two geometries / bikes messes me up too much, i am too old and don't have the brainpower to switch back and forth ;-)
well over $7k invested.
asking $4k cash obo
can have it boxed by LBS and shipped at buyers expense
Adult / mature buyers with cash in hand preferred.
https://photos.app.goo.gl/GTtp7ER7bu9csBQf6
Brakes SRAM Code RSC
Rotors SRAM Centerline 180mm and 200mm
Fork RS Pike RCT3-B1, 2017 model, TRAVEL 120MM, AXLE 15X110MM BOOST™, SPRING DEBONAIR, 51mm offset, min rotor 180mm
incl MRP Ramp Control
Crank RaceFace Cinch 30T
bottom bracket Wheels Mfg PF30-OUT-30MMAC, PF30 Outboard Angular Contact BB for 30mm Cranks
Crankarms RaceFace Turbine Cinch 175B
Derailleur SRAM X01 Eagle 12sp Type 3
Cassette SRAM XG-1275 GX 10-50 12sp
Chain SRAM X01 E 12S 126L SIL
Shifter SRAM X01 Eagle 12sp with Discr
Seatpost BikeYoke Revive 185mm
Grips ODI Rogue with blue lackjaw clamps
Seat Ergon Sport
Pedals Spank Oozy Trail
Stem Industry Nine A35 60mm (Deity Copperhead 35 taken from the new Stumpjumper, and several others to choose from, see my other thread)
Bar RaceFace Next R Carbon 35mm 800mm 20mm 8deg back 5deg up
Tire Sealant Orange Seal
Wheels Industry Nine Backcountry 450 wheelset, rear rim replaced and wheel rebuilt with new HYDRA freehub March 2021 by Ricky Muehl (i9)
Tires Schwalbe, 27.5x3.0, Rocket Ron, Nobby Nic, Snakeskin, Addix Speedgrip, just mounted this summer for the trip out west
font axle - i9 matchstix axle / multi tool
stock geometry - be reminded this has changed based on the above modifications / parts !
S M L XL XXL
REACH 400mm 420mm 440mm 458mm 476mm
TOP TUBE LENGTH, HORIZONTAL 575mm 608mm 633mm 656mm 679mm
STACK 605mm 614mm 629mm 643mm 661mm
WHEELBASE 1112mm 1136mm 1161mm 1185mm 1211mm
CHAINSTAY LENGTH 430mm 430mm 430mm 430mm 430mm
FRONT CENTER 686mm 708mm 735mm 760mm 786mm
BB DROP 51mm 51mm 51mm 51mm 51mm
SEAT TUBE ANGLE 73° 73° 73° 73° 74°
HEAD TUBE ANGLE 67.5° 67.5° 67.5° 67.5° 67.5°
SEAT TUBE LENGTH 394mm 434mm 470mm 505mm 555mm
BB HEIGHT, 29X2.3" 319mm 319mm 319mm 319mm 319mm
HEAD TUBE LENGTH 100mm 110mm 115mm 130mm 150mm
BIKE STANDOVER HEIGHT 755mm 781mm 806mm 830mm 866mm
FORK RAKE/OFFSET 51mm 51mm 51mm 51mm 51mm
FORK LENGTH, FULL 510mm 530mm 530mm 530mm 530mm
TRAIL 95mm 95mm 95mm 95mm 95mm
[IMG]
[IMG]
this year of Fuses is "different" and i believe it was the only year that came with the welded "hole" driveside chainstay and that had this geometry.
I believe XXLs after 2018 were all "smaller".
That'd be an excellent bikepacking bike for someone 6" taller than me, very nice build with the I9 wheels/hubs and 27.5+, GLWS!
that is correct. as stated the only thing that remains from that build is the frame itself and the headset.
for those interested i could tally up the cost of all parts which was an initial $4,641.24 before the i9 and then other tweaks like MRP ramp control etc. that came in the initial summer of riding. It has been rocksolid since and requires nothing but new sealant in the spring (just done a few weeks ago).
The i9 wheels I had custom made to my spec at i9, since someone mentioned bikepacking, they
did a great long term review on them : https://bikepacking.com/gear/industry-nine-wheels-review/
super hard to come by now, could not even find sold listings on ebay.
haha - just noticed there is a pic of ricky muehl who rebuilt / converted to hydra rear hub in the article.
M meadow build
