2019 Ford Transit Quigley 4x4 AdventureVan
Gravity
SOLD!!
Selling our 2019 Demo vehicle - a well equipped '19 Transit T250 148 MidRoof, EcoBoost Quigley 4x4, 3.73 LimitedSlip, Heated/Power/Leather seating, Sync Bluetooth Audio etc.... Very well setup from the Factory.
Buildout was done by our company - InspiredVan out of the Jackson Hole, WY area - we specialize in the uplift of Sprinters and Transits into a very versatile Gearhauler, People Mover and People Sleeper.
This van features the yet to be released Adventure Wagon interior system plus their revolutionary MOAB Bed design. www.adventurewagon.com As one of their Leading Partners and DIY Workshop Instructors we took it upon ourselves to modify their upcoming High Roof layout into a MidRoof - this van is one of a kind!
Build Highlights
-Heavily Insulated for the Teton Winters with a combo of Havlock Wool plus 3M Thinsulate
-Black Powdercoated L-Track throughout for anchoring your gear
-MOAB Platform Bed
-Aluminess Front Bumper w/ KC Hilite Foglights
-Flarespace Flares for more width internally and to allow sleeping widthwise w/ integrated 10x33 Windows
-CR Laurence Awning window on Drivers Side
-Efficient Power supply w/ a GoalZero Yeti 1400 charged via alternator with the GZ LINK system
-LumiCoin LED Light pucks are individuals;y switched and feature red and white lighting with integrated dimmer control
-MaxxAir 7500 Fan
-SnowMaster DL56 Stanless Fridge w/ insulated cover
-Espar M2 gasoline furnace
-Scopema Pass seat Swivel
-Modified Ford Transit 2 seater bench seat, easy to remove or reposition
-Upgraded wheel tire setup. Method 701s w/ 245/75/17 Falken Wildpeak AT3Ws
-VanCompass Rear Shock mounts for greater ground clearance
-Full setup of Strawfoot Handmade insulated windshades
This van is available NOW As it Sits for $83.5k - if the end client wishes other items we can easily accommodate. Items like a Roof Rack, Internal storage cubbies, Galley Cabinet etc...
Currently has 9k miles on it and will go up slightly as it is driven locally. Located here in the Jackson, WY area
We will be taking more detailed photos in the coming week
For more info please shoot us an email 'inspiredvan@gmail'
Thanks!
Gravity
Yes, it is roughly 5'9-5'10 inside. I"m 5'11 and just barely brush the ceiling standing up in it. Significantly better manners on the windy open roads vs the High Roof and the MidRoof IMO is a far cleaner looking vehicle vs the HR especially if you opt for a Roof Rack
Gravity
Closer Look at the GoalZero Yeti1400 and SnoMaster DL56 Fridge...
Gravity
Yes, it has the 3.5L EcoBoost motor. Absolutely a Blast to drive, tons of power/torque. Zero comparison to the diesel in a Sprinter IMO. And greater tow capacity too
Gravity
Yes, $83.5k as it sits - just corrected the original post. To answer a few inquiries, YES if you were not 100% into the retro VW Plaid ceiling I can swap it out for the Grey or even Blue tweed fabric used in the rest of the build...
bcnaz
Can you share the platform to ceiling height? Looking to be able to sit upright so needing ~36" Or is the bed also mountable on the lower L-Track? Also - would the passenger seat mounting brackets easily swap over to a 3 seat bench? Need to seat 5. Thanks
Gravity
The bed platform is adjustable on the Vertical L-Track from just over the top of the wheel wells to about 12" from the ceiling. Currently it is 38 1/2" from the floor to the top surface of the platform and then roughly another 31" up to the ceiling. The current seating is only compatible with the 2 seater Transit bench seat, another run of L-Track would need to be installed/thru-bolted for it to work with a 3 seater
Breezy78
