2020 Barely Used AT Overland (Adventure Trailers) Summit Camper – 6.5' Full Size Truck Bed
rockymtntaco
$11,500
This 2020 AT Summit truck top camper has only been slept in four or five times. We purchased it in February of 2020, right before COVID hit. We were going to build an overlander to take to Alaska, but plans all changed after the plandemic. When you pop it up it still smells new. The interior, bed, ceiling and wall carpeting are basically brand new. The outside does have a some mild bush-induced pin striping from narrow roads. Fits a 6.5' full size truck bed. Smoke free / pet free interior.
Upgrades:
  • The camper has been wired for solar, there is a plug in the roof that will accept solar inputs and the wiring is exposed inside the camper.
  • There are intentionally no windows on the sides for security reasons. Rear hatch/door does lock on both sides.
  • There is an aluminum cut out for accessing the cab, so you can pass from the cab through to the camper. We kept the aluminum cut out, and can be reinstalled so that if someone broke into the cab, if the cut out has been re-installed, it would prevent someone from having access to the bed of the truck.
Camper is currently installed on a 2017 Tundra in the Durango, CO area. We will be happy to meet you at a shop nearby to have them remove it from our truck and install on yours if necessary. AT Overland has a list of approved shops on their website. Buyer is responsible for romoval and reinstallment costs.
For more information, see the link below on AT Overland's website:
https://atoverland.com/pages/at-summit-truck-topper
STANDARD FEATURES
  • Easy 30 second deployment and stowage
  • Sleeps 2 standard
  • Built in mattress on lift assisted platform 48” x 80” x 2”
  • Insulated sleeping platform and shell walls with carpet covering
  • Bedding can remain in place when closed
  • All aluminum & composite construction
  • Roof can be walked on (600 lbs max)
  • Locking lift gate / rear hatch
  • Ruggedly designed for 4×4 travel
  • All season tent with no-see-um mesh windows, clear vinyl and privacy panels
  • Interior carpeting
  • Standard color: Clear coated aluminum.
(Base finish is protective clear coat on raw 5052 aluminum, light surface scuffing can be expected from manufacturing handling)
MATERIAL SPECIFICATIONS
  • Insulated aluminum composite panels
  • Water repellent, UV resistant Firesist awning fabric
  • Stainless Steel Hardware
  • .090” 5052 CNC formed aluminum
  • Base Weight: 360lbs
  • Roof max weight recommendation for opening 100lbs
  • 2.0" Hi-Density Foam Mattress measuing 80” x 48”
  • Bed weight rating of 500lbs
Wolfbox
