2020 Mercedes Sprinter 4x4 - Low Roof - Low Milage
Distagon Sid
$114,500.00
2020 Mercedes Benz Sprinter low roof van with 4 wheel drive and only 6000 miles
Very clandestine if your lookin for something different this is it.
Professional built by 40 North Designs https://www.40northdesigns.com/sidney
Van Compass Stage 4.3 suspension package with Falcon 3.3 adjustable shocks
Falken Wild Peak A/T tires
5000lb trailer hitch
Vantech H2.1 roof rack with channel for mounting accessories
Aluminess steps, rear door ladder, storage box, mounting for bike rack
2 1UP bike holders (not currently mounted)
Roof top storage box
240 watt 24 volt solar panel
Baja Designs exterior LED lighting
Drivers and passengers windows are tinted
Drivers and passengers swivel seats installed
Black coin dot flooring in the entire van
Walls, roof and floor are all fully insulated with a high R value denim insulation
LED lighting throughout the van
Maxxair fan with ability to pull or push air plus remote
Flatline Van Company bed
30 gallon water tank
Electric water pump
Stainless Steel sink
Dometic D21 Stainless Steel stove top with electric igniter and propane fuel source
Victron Cerbo + GX Touch 50 for electrical system management
Victron Energy MPPT Charge Controller
Victron Energy Bluetooth battery monitor
Victron 1200 watt inverter
Victron DC to DC battery charging
Two 100 aH 12V Lithium batteries with low temperature operation built in for cold weather
Fuse panel and breaker box for solar
Custom switch panel
120v outlets
USB outlets
12v cigarette lighter outlet
Vitrifrico 4.2 cf fridge freezer
Webasto Air Top 2000 diesel heater. Thermostat is on the switch panel with high altitude conversion
WeBoost Cellular phone reception extender
Sonos Move portable speaker with mount
Soft close cabinet drawers
Valuables storage box with bench cushion
Vanmade window shade and coverings
CargoGlide rear pullout storage slide with 1500lb capacity
The van is located in Loveland CO.
2eleven
