SOLD - 2021 Boreas XT Camper trailer with James Baroud Hard Shell roof top tent
margauxd
This is a great camper; we are sad to see it go. Since the initial purchase our family has doubled in size, so our camping ideas have changed at least for the next few years. With two littles we are not doing much back country camping. We have only used it a handful of times, and still smells brand new. It has been living in our garage, so it has been protected from any sun damage or hail. The camper is small enough to store inside a standard garage, but the rooftop tent will have to come off to get it in. Trailer and roof top sleeps 4. The trailer is built to go anywhere, great for hunting, back country skiing trips, and places where a normal RV just can't get in to. Skies the limit.
Asking $32,500.
Located in Littleton, Colorado 80127
Pictures below are half ours with roof top tent and cube, other half are stock photos because we just haven't taken it out enough.
The details below are mostly from Boreas site. Here is a walkthrough of the camper from Boreas YouTube channel:
  • Cruise Master CRS2 axel-less independent suspension
  • 235/80/R17 BF Goodrich All Terrain Ko2 Tires
  • 17" steel Pro Comp Wheels
  • Full sized spare
  • Electric Brakes
  • Custom tongue box w/ Zamper Obsidian Solar plug
  • 100-watt Zamp Obsidian solar panel
  • Victron charge controller
  • Composite fiberglass exterior
  • Cruise master D035 Hitch coupler
  • Rear leveling jacks
  • 7point plug
  • Front jack with wheel
  • All Led lighting with reverse lights
  • 2 Exterior LED porch lights with dimmer
  • Custom Aluminum Roof Rack
  • 8' x8' Side Awning
  • Instant hot water shower
  • Load bearing fenders
  • 19"of ground clearance
  • 2 l1lb propane tanks w/ mounts
  • 2 Jerry can mount
  • Additional rack above storage locker
Interior
  • Two cabin doors with windows and screens
  • Sleeping space is 57"W x 79"L x 45"H
  • LED lighting with dimmer
  • 12v/USB power source with battery monitoring gauge
  • HDPE cabinetry
  • FRP composite interior paneling
  • 4.5" memory Foam Queen bed, wrapped in organic cotton
  • 1.5" fully insulated cabin
  • Propex 6500 forced air furnace
  • MaxxAir 6200 All-weather Fan - 10 speeds w/ reverse and thermostat
Galley
  • Stainless steel pull- out with 20,000 BTU Partner cookstove
  • Stainless-steel pull-out sink on demand water
  • Pull out Truma C60, 60-liter electric Cooler Refrigerator/Freezer
  • 30 Gallons of onboard freshwater with self-priming pump
  • 11lbs onboard propane
  • All pull out accessories mounted on 500lb sliders with lock in/lock out options
  • LED lights with dimmer
  • 12v/USB power source with battery gauge
  • HDPE cabinetry
  • Stainless steel countertop
Electrical System
  • 12v/110v Intelli-power Control Center
  • Shore Power with battery charger and tender
  • 100w Zamp Obsidian solar panel
  • Victron Charge controller with battery monitor
  • Replaced Battle Born Lithium battery with 2 12v Super Start Marine Deep Cycle batteries
  • 12v tow vehicle charging system
  • 2000w inverter
Trailer Dimension and Weight
  • Cabin Exterior - 60" Wx110"L x48" H
  • Overall, Height with Awning - 80.5"
  • Cabin Interior (sleeping) - 57"W x 79"L x 45"H
  • Overall Length - 16"
  • Overall Width (fender to fender) -7'
  • 2,200 lbs. dry weight
  • 210 lbs. tongue weight
Trailer Frame
  • CNC cut chassis
  • 3" x2" x 1/8" steel frame
  • Powder coated
  • Rear 2"reciever hitch
  • Front 2"reciver hitch
Add Ons
  • ARB Cube 2500 x 2500 Deluxe Awning Room with Floor, attaches to awning
  • We also have a new James Baroud awning tunnel that has never been used or attached to the tent.
James Baroud Evasion roof top tent
  • Shell: 4 Fiberglass layers with UV coating
  • Fabric: Waterproof all-season fabric
  • Openings: 3 doors and 360º windows
  • Mattress: 65mm (2.5″) High Density Foam
  • 51"W x 79"L x 39"H
  • Closed Height 13"
  • 134lbs
  • Quick Release Tent Mount Kit - by Front Runner
clearwater
