2021 Expedition trailer
WJ Overland
Custom built 2021 expedition trailer. Approx size 5wx12lx6h. Timbren 4" independent suspension with Jeep JT bolt pattern. Black steel rims with 35" tires.
Pretty much everything goes with it, so just hook up and go camping. Plates, cups, pans, etc... Come to Colorado, look at it, buy it and go camping!
Boxes started as a Knapeheide service bed. Trailer still has s/n plate so if needed, you can still get replacement doors, latches, etc. from Knapeheide. I completely disassembled the original bed, repaired any damage. Narrowed the boxes by 18" when I installed onto custom square tube frame. All LED lights including back up lights on trailer. 3 leveling Jack's. This trailer can be level no matter where you park it. Under trailer/rock lights. Great when towing at night off road or lighting around camp. Each cabinet has led light on door switch.
Fits/tracks perfectly behind almost any tow vehicle.
Loc and roll tow hitch
Smittybilt RTT 2-3 person
OVS 270 awning with wall kit.
Iceco VL 60 frig and freezer including insulating cover
Custom double slidout for easy access
Renogy solar;
300w mounted w/200w remote plug in panels
200ah AGM battery
1000 watt inverter
Solar charger
All wires in/out are fused or breakers
Foldout sink with hot and cold water (propane tankless 1.58gpm water heater)
25 gallon fresh water tank
12vdc Shurflo water pump
Shurflo accumulator
20lbs propane with 4 individual control manifold. (Cook top, water heater, grill, firepit)
2 quick connect at rear of trailer for propane grill and/or fire pit. Firepit included!
Coleman 2 burner cooktop
Coleman stovetop oven
Diesel heater with rotopax 2 gal diesel tank
Stereo/mp3 player with speakers
Folding table
Bathroom/shower privacy enclosure
Hot and cold water shower
3 sensor thermometer. You can monitor the temperature of the refrig, freezer, inside of trailer and ambient temps, even while towing
Includes spare matching rim, no tire
My wife and I have taken this out for a nine day adventure and had plenty of everything, food, water, propane, etc...
Trailer has approximately 8000 miles with no issues.
We tow it with a Jeep Gladiator 3.6lt engine, no problem
Trailer fully loaded, food, water, propane, cloths, etc... 3k lbs
We have taken it on forest service roads, rock crawling trails at 11k ft elevation. Hwy, interstate at 70mph without issues.
Using the tent, awning, and wall kit with the diesel heater and/or fire pit, I have camped in rain and snow locations and have stayed very warm and dry, even wearing shorts! So, really could be used as a 4 season expedition camping trailer.
$16,800 (price reduced $15,000)
No trades, cash rules!
I've personally seen this trailer through the build process and have been out with the builder on several trips where I could see it up close. The build quality is second to none and he's thought out all of the systems very thoroughly. I'd highly recommend!
2eleven
