2021 Mission Overland Summit - $29,500
BirfMark
Selling our much loved, but lightly used, 2021 Mission Overland Summit camper. This incredible rig is super lightweight (less than 3,000lbs), super easy to set up and take down. Sleeps four with the bunks, believe it or not!
I towed this with my Tacoma from Austin, TX to Yellowstone and back this summer. Great trip, and towed extremely well.
Comes with 190 watt roof mounted solar panel, Victron MPPT charge controller and 200 amp hour Renogy battery. I have yet to run into a situation where we've run out of power.
There is a Truma 12v/120v dual compartment fridge/freezer to keep your food and drinks cold. It's on a pull out slide on the passenger side.
For heat, there's a Truma propane furnace/hot water heater. I will include an 11lb propane tank, and a 5lb backup tank. Both are already mounted to the front for easy access.
Tons of storage, both on the front gear shelf, the exterior compartments, and the interior ones.
There is a 270° Overland Vehicle Systems (OVS) awning, complete with all poles, mounted on the passenger side so the pull out kitchen and cooler can be covered. There is also an OVS shower/change room on the drivers side.
2 burner Dometic propane stove
Sink with hot and cold water
37 gallon fresh water tank.
All LED lighting, inside and out
Everything on this camper is 100% functional, and ready to travel.
For the right price, I might be persuaded to do a road trip to meet you for delivery. Currently located just east of Austin, TX.
A few more pictures.
Feel free to ask any questions you might have.
Wolfbox
