2021 OVERLAND EXPLORER CAMP M
ranesandpoint
If you are looking for an overlanding camper that is super durable, light and great for winter camping this is what you want. Camper only. We will also deliver if you cover gas costs (we'll keep receipts). Camper details below. Priced to sell a new camper with all our accessories would cost $50K. TRUCK no longer available.
Camper only: $35,000 OBO
2021 Camp M Overland Explorer in mint condition-well taken care of when not in use parked in garage or under carport-winterized.
Dimensions: Exterior: 122"L x 77"W x 61"H closed, 83"H open
Dimensions Interior: 118"L x 72.75"W x 81"H open
Dry Weight: 975 pounds
Features:
-Cold weather package
-includes 10 rubber feet protect camper and truck bed 4 torque lift tie down latches
-powder coated aluminum extrusions
-OVE generation 4 composite floor
-Walls and roof R8
-Insulated soft walls R4
-locking roof supports
-gas struts assist for lift -DOT LED Lights
-Truma CP and Vario heat w/thermostat
-Truma AquaGo LP Gas instant water heater
-continuous hot water with sigiva outside shower connection and hose extension
-Truma C63 refrigerator
-10 speed Maxxfan roof vent
-20 gallon fresh water tank w/12v Flow Max Fluid Pump -s/s sink w/flush mount glass top
-propane connection for portable cooktop
-entrance door grab handle
-screen door
-aluminum propane cabinet w/10lb bottle
-front east/west dinette folds down into a small bed (28'x63.25") w/under seat storage
-flip up countertop
-large exterior storage access via locking cargo door
-marine canvas cushions
-4.5" medium density foam cushions -King Bed extension
-high traffic grade Lonseal vinyl flooring
-fire rated thermal break kit and fire extinguisher
-structural powder coated aluminum interior cabinet cabinetry
-LP/Smoke and CO detectors
-Dual USB Plug -12v auxiliary connection
-LED entry Light
-LED interior lights (dimmable)
-LED exterior lights
-REDARC BC/DC 1240 charger
-Dual Pane acrylic side window
-RIECON Titan 4 corner camper jacks heavy duty 2000 lb per jack capacity full 36" lift
-180W solar panel
-OHMMU Gen 3 Group 31 Premium Lithium Battery 156 Amp hours 2000Wh built in BMS
-Canada Proof Battery Monitor
-Alucab 270 shadow awning (length 2.6m, weight 24 kg, shade area 10m2, aluminum construction, RHS mount, material is acrylic impregnated, with a heat reflection silver coating on one side. Has additional water repellent coating on surface side, built in fungal resistance to prevent mold, water penetration/water column capability greater than 1000mm/1m -powder coated aluminum awning adapters
-OVE Molly rear accessory rack w / one 2 gal water rotopax
For detailed review of camper and more pictures: Overland Explorer Camp M Review | Encouraging the Minimalist Life (rgbadventures.com)
https://rgbadventures.com/2024/04/27/overland-explorer-camp-m-review/
email: ranebendor at gmail dot com
ELShockley
