2021 Turtleback Expedition Trailer | T3 Build w/ Lithium Package and Alucab RTT | Orange County, CA. | $32,500
ZubesYo
2021 TURTLEBACK EXPEDITION SERIES T3 UPGRADED BUILD PACKAGE
Price: $32,500
Contact Information:
Shawn - 425-785-8977
No issues and the trailer is in like new condition.
- Has the low roof rack so the trailer fits under a standard garage door and sits at 80.5"-81" off the ground with the current Alucab RTT.
Electronics and Battery Systems:
- Lithium Dual Vitron Batteries
- Alucab Gen 3 Rooftop Tent
- 2000 WATT PURE SINE WAVE INVERTER WITH BLUE SEA 150 AMP BREAKER
- ZAMP 90WATT PORTABLE PANEL PRODUCES 90WATT AT 5AMPS, WEATHER RESISTANT, 5 STAGE, 10AMP CHARGE CONTROLLER, ALLIGATOR CLAMP ADAPTER INCLUDED.
- ADDITIONAL CHARGE PORT (DRV REAR KITCHEN, PASSENGER REAR KITCHEN, MAIN STORAGE COMPARTMENT)
- C-SERIES RGB MULTI-COLOR MULTI-USE LED 6-LIGHT SYSTEM
- 6 x KC C-Series RGB LED Rock Light Pods
- EXP RIGID REVERSE LIGHT KIT
- EXPEDITION RIGID REVERSE LIGHT KIT
- 4 EXTERIOR FLOOD LIGHTS, 4 STORAGE BOX LIGHTS, 1 MAIN STORAGE AREA LIGHT, 1 NOSE BOX LIGHT, 1 UTILITY AREA LIGHT, 1 CONTROL PANEL LIGHT, 3 UNDERCARRIAGE GREEN "TURTLE" CONVENIENCE LIGHTS
- 7-PIN TRAILER CONNECTION: INCLUDES CHARGE LINE, BRAKE CONTROLLER LINE, RUNNING LIGHTS, SIGNAL LIGHTS, AND REVERSE LIGHTS
TURTLEBACK SIGNATURE SUSPENSION:
- TURTLEBACK EXCLUSIVE WITH ICON VEHICLE DYNAMICS DESIGNED AND TESTED REMOTE RESERVOIR SHOCKS, CUSTOM PROGRESSIVE SPRINGS
- EXPEDITION PREMIUM TOPO GRAPHICS
- DUAL / Ark Drop Down Corner Trailer Stabilizer Jacks
- 16 INCH STEEL WHEELS WITH ALL-TERRAIN 285/75R16 TIRES
- SWING OUT TAILGATE WITH FLIP-DOWN TABLE, SPARE TIRE MOUNT, AND ROTOPAX MOUNT. MOUNTED ON IDLER HUB ASSEMBLY FOR AXLE SPARE.
EXPEDITION SLIDE-OUT KITCHEN:
- INCLUDES PARTNER STEEL STAINLESS STOVE WITH DUAL 10,000 BTU 18" BURNERS, LID, AND ADJUSTABLE WIND GUARDS, DUAL PRESSURE PROPANE SYSTEM, DOMETIC DEEP WELL STAINLESS STEEL SINK AND FAUCET WITH TEMPERED GLASS
- INTERIOR SIDEBOX MOUNTED CONTROL PANEL WITH BLUE SEA 8 CIRCUIT BREAKER PANEL, BATTERY POWER DISCONNECT, 2.1A USB CHARGE PORT, 12V SOCKET, OLED VOLTMETER, AND WATER HEATER SWITCH.
- DUAL STAINLESS STEEL FOLD DOWN PREP TABLES
- 42 GALLON, FOOD GRADE, BPA FREE, WATER TANK WITH EXTERNAL, LOCKABLE FILL DOOR (VENTED)
- 12V ON DEMAND WATER PUMP 3 GPM, 55 PSI, SELF PRIMING
- Dometic 6 GALLON DIRECT SPARK IGNITION WATER HEATER
- ACCESSORY 5LB PROPANE TANK AND MOUNTING BRACKET
- TURTLEBACK CUSTOM FRIDGE SLIDE
Shower Enclosure:
- 23Zero SHOWER ENCLOSURE
- LOCKABLE EXTERIOR USE SHOWER WITH DEDICATED VALVE CONTROL, 5' PVC HOSE, AND SHOWERHEAD
- 11 LB PANCAKE TYPE TANK FOR PRIMARY ON-BOARD SYSTEMS (DRIVER'S SIDE)
dhuss
