2022 Kimbo Camper Series 6 in Port Townsend, WA
Zee Uballe
KIMBO CAMPER FOR SALE $29,500
AD_4nXfKXJdfi3uqsrC6S1_i6aGRAdleAFk-c5mj_plIUkq01Dp13e3diGYlfPEXBxHaiNpU9Uf4mGDGhIt3P6LdFEunW5VKOHgkXQQQVKg2-Zb7C7WVzRr46A-c_itWeOpVQhAbhBEwJQ
We love our truck top camper but the time has come to sell it.
We picked up our Kimbo Camper from the factory in Bellingham WA in May of 2022 and have made two or three camping trips a year since then.
These light weight and well built campers don’t come on the market often.
Our camper is available for pick up in Port Townsend WA.
We paid $34,000 for the camper and then added $2,000 in modifications and improvements.
We added a backup camera, custom cushions for the side benches, a one burner propane burner with a split gas line to the propane tank and a built-in step for easier access to the bed loft.
We have worked hard to keep our camper in great shape.
Our Kimbo build is # 202. It includes these standard and extra optional Kimbo 6 features:
  • Lightweight, Aluminum Construction. Kimbo campers are designed for easy maneuverability, with a durable, sealed and riveted frameless aluminum shell with a brushed finish. Because it’s lightweight it is more fuel efficient and can be used by a smaller truck like our Tacoma with a five foot bed (we keep the tailgate open for the fit).
  • R5 foam insulation with a brushed fabric interior in gray.
  • Off-Grid Friendly. They are designed for extended off-grid operation, with features like solar and propane power, marine sink/water tank, propane heat source and efficient storage solutions.
  • Kitchen/Sink module for food prep and use as bathroom sink. Stainless steel marine sink on birch counter with hand pump faucet and 2.5 gallon under counter water tank.
  • Dometic fridge and freezer. 12 v/110 v 1.3 cubic ft fridge with birch cover and partial kitchen top.
  • Three double-pane windows with roll up/down screens and black out shades.
  • Solar system: 200 Watt solar, along with a 12v sealed battery with integrated 110v outlets & USB ports, and backup battery.
  • Propane fireplace and chimney with 12 v circulation fan for constant off-grid heat source.
  • Powerful 3-speed reversible roof vent fan with skylight.
  • Air conditioning unit when connected to shore power.
  • Teak entryway/mudroom.
  • Ample Storage: Gear closet, metal basket shelving and wooden storage unit with cubbies : interlocking birch mounted to center wall and dining/desk surface.
  • High efficiency dimmable LED lighting, programmable with remote control.
  • Loft bed with full sized mattress. Over cab view from bay window to look out at the stars.
  • Two cushioned seating areas for dining, reading or meditation.
  • Slide-out birchwood desk/tabletop.
  • Solar outdoor perimeter lights, programmable as on-off or motion sensor.
  • Fire extinguisher and smoke/carbon monoxide propane alarm.
  • Exterior propane bay for a 30-pound propane tank. Strap, insulation, water drain holes and lockable.
  • External 120v shoreline power connection.
  • Side mounted, removable jack lifts.
  • High strength tie down brackets.
  • Weight approx. 1000 pounds.
  • In addition the Kimbo comes with
    • Custom made bench cushions in slate gray, matching the interior fabric
    • One burner propane stove
    • Dehumidifier
    • 30 lb. propane tank, nearly full
    • Back up camera and external wiring
    • Portable toilet (used but clean) if desired
    • Bedding (used but clean) if desired
For more information go to Kimboliving.com https://www.kimboliving.com/details
2eleven
