greggearhead
Priced to sell.
2022 Kimbo 6ft Camper
This is a one-owner, very clean and well cared for Kimbo slide-in camper. Was used in a Tacoma, which handled the weight easily (one overload leaf spring was installed).
Kimbo campers are known for being well built (by hand – custom to order), well designed and lightweight. This one was purchased after covid started and the owner spent a year living in it full time, then used it for travel and vacation camping. It is in excellent shape, with some upgrades that make it even better.
The standard 2022 Kimbo 6 foot series camper includes the following:
This one has some extra wire baskets and bins, many of the interior panel fasteners were replaced with eye bolts, which makes hanging things inside super easy. There are two small USB powered fans that keep air moving around the cabin without being overpowering or loud.
The owners manuals for the appliances are included – the owner was very detail oriented. These are not easy to find, and when they do come up, they don't last long, because they are so sought after. Don't miss out on this one.
New price was over $30k, and these hold their value extremely well. I have seen two very similar ones priced at $29 and $32k. Asking $24,500 for a quick, easy sale.
- Lightweight, Aluminum Construction. Kimbo campers are designed for easy maneuverability, with a durable, sealed and riveted frameless aluminum shell with a brushed finish. Because it’s lightweight it is more fuel efficient and can be used by a smaller truck like our Tacoma with a five foot bed (we keep the tailgate open for the fit).
- R5 foam insulation with a brushed fabric interior in gray.
- Off-Grid Friendly. They are designed for extended off-grid operation, with features like solar and propane power, marine sink/water tank, propane heat source and efficient storage solutions.
- Kitchen/Sink module for food prep and use as bathroom sink. Stainless steel marine sink on birch counter with hand pump faucet and 2.5 gallon under counter water tank.
- Bodega 12V Fridge -
- Three double-pane windows with roll up/down screens and black out shades.
- Solar system: 200 Watt solar, along with a 12v sealed battery with integrated 110v outlets & USB ports, and backup battery.
- Propane fireplace and chimney with 12 v circulation fan for constant off-grid heat source.
- Powerful 3-speed reversible roof vent fan with skylight.
- Air conditioning unit when connected to shore power.
- Teak entryway/mudroom.
- Ample Storage: Gear closet, metal basket shelving and wooden storage unit with cubbies : interlocking birch mounted to center wall and dining/desk surface.
- High efficiency dimmable LED lighting, programmable with remote control.
- Loft bed with full sized mattress. Over cab view from bay window to look out at the stars.
- Two cushioned seating areas for dining, reading or meditation.
- Slide-out birchwood desk/tabletop.
- Solar outdoor perimeter lights, programmable as on-off or motion sensor.
- Fire extinguisher and smoke/carbon monoxide propane alarm.
- Exterior propane bay (with propane tank). Strap, insulation, water drain holes and lockable.
- External 120v shoreline power connection.
- Side mounted, removable jack lifts.
- High strength tie down brackets.
