GENERAL
♦ Sleeps 3 (2 adults and maybe a small child)
♦ 1x Custom pillow-top Queen Size innerspring mattress (we replaced this)
♦ Mattress – 79” L x 58” W x 9” H
♦ Combination of welded aluminum 2″ x 1″ Hot Roll Steel Rectangle Tube and 1″ X 1″ square aluminum alloy
DIMENSIONS – with Aircon
♦ Open – 22’1″ L x 14’3″ W x 10′ H
♦ Closed – 22’1″ L x 7’8″ W x 10′ H
WEIGHTS & RATINGS
♦ Dry weight 5254 lbs
♦ Tongue weight 458 lbs
♦ GVWR 6147 lbs
PRICING
$50,000.00 O.B.O
MILEAGE
3,240 miles
CHASSIS
♦ 5″ x 2″ – Q345 Galvanized Steel Hot Rolled Rectangle Tube Frame
♦ Cruisemaster™ DO35 hitch
♦ 10″ swing-up and lockable Jockey Wheel
♦ 16×7.5 6/139.7 Aluminum alloy wheels fitted with 265/75R16 Goodride MT tires + 2 spares
♦ X-TRACK Independent coil spring suspension with 2x TOUGH TRAX Shock absorbers on each side
♦ 12″ electromagnetic brakes with handbrake and drawbar mounted emergency breakaway system
♦ 4 x heavy-duty lockable and adjustable drop-down stabilizer legs
EXTERIOR
♦ 14.3′ 12V electric cassette awning
♦ Full annex, enclosed roof, walls, floor, and draft skirt
♦ 2x 20lbs propane cylinder and cylinder holders
♦ 2x 5 gallon jerry can holders
♦ 2x 21 gallon fresh water tanks + 1x 21 gallon grey water tank
♦ Water delivery – 12V electric marine diaphragm pump
♦ External Slide out stainless Steel body with propane cooktop & washboard sink with plumbed hot & cold water supply
♦ Chequer plate stone guard with forward-facing and rear wheel mud flap protection
♦ Integrated front toolbox
♦ Manually operated pull-down entry step
INTERIOR
♦ Internal Laminated benchtop with glass lid plumbed sink and propane cooktop and internal refrigerator
♦ Dometic CTS 4110 Cassette toilet + Hot and cold plumbed wash sink
♦ Hot & cold plumbed wet bath
MAJOR APPLIANCES
♦ Dometic Penguin II High-Efficiency Low Profile Rooftop Air Conditioner
♦ Truma Aquago Comfort Plus instant hot water system (propane-operated)
♦ Dometic DFSD 12111 Furnace (propane operated) / 12v compressor refrigerator 6 cuft
ELECTRICAL
♦ 2 x 150W solar panels
♦ 2 x 100Ah Lithium Iron Phosphate batteries
♦ BMPRO Battery Plus35-11-HA Battery Management System with RVVIEW2 battery monitor and BC300 external shunt
♦ AIMS Power 1500W Pure Sine Wave Inverter
♦ Internal 12V LED lighting throughout with wireless switching
♦ External 12V LED lighting throughout, position markers, indicator & stop/tail lights + awning and offside wall lighting and forward and rear spotlights with blue light up entry door grab handle
♦ Light Connection Plug – 7-way trailer connector (SAE J2863 type)
♦ Stereo head unit with internal & external speakers
♦ 19″ LED TV
INTERNAL POWER OUTLETS
♦ 5 x 12V accessory sockets
♦ 4 x 5V dual USB charging ports
♦ 6 x Double 110V outlets
EXTERNAL POWER OUTLETS
♦ 1 x Anderson plug
♦ 1 x 12V accessory outlet (outdoor Kitchen location)
Included Accessories
50 Amp Electrical management system
Custom dinette (Lagun Table mount system)
Brand new custom queen size bed
TPMS tire pressure/temperature monitor
Electronic Sway controller
Assorted chemicals
Assorted hoses
Two stage water filter
Wheel Chocks
Water pressure regulator
