2023 GeoPro 20BHS
NoTraxx
I picked up a 23 GeoPro 20BHS a couple of weeks ago. Finally was able to spend a few nights in it.
The tow was pretty easy, both on the Hiway and across the pasture.
Specs say that tongue weight is 495, I’ll verify later. The GVWR is 4500. Sooooo for my tow vehicle I am below the weight to need a WDH but I have an Anderson just in case and also to use on other trailers.
I wouldn’t take this down any roads that are to rutted but lightly maintained roads would be a go. There are some gravel roads around, I may take the trailer down to see how it does with and without the WDH. I think I can set up a go pro in the trailer to see how things bounce.
So far I have been staying in the trailer solo, but will be taking the family out for a weekend trip soon. I’ll update then how it goes with the family.
Few burgers on the griddle that came with it.
Some storage opened up after removing the panels.
So far spent a few nights at los ranchito with power and electric. Drug it across the pasture to the pond to see how it does on dirt track. Not too bad, need to secure everything inside before moving around.
Things to do,
Upgrade the solar
Looking to replace the AC with a mini split heat pump.
Install some track, to open up some space in the fwd storage.
Install some Milwaukee packout bases to secure….well the Milwaukee pack out boxes.
Upgrade the inverter. (Part of the solar upgrade)
Remove the TV/WiFi ranger antenna
Did a little work on the pass Through storage, I laid down some c channel and converted the paneling into slide doors.
Mounted a Milwaukee pack out base plate and am using the medium box. Able to open it a bit in place as well.
M meadow build
