2023 Ram 3500 Limited DRW - Cummins HO - Carli Pintop - $70k+ Modification's
AdventureMotors
*** SOLD ***
Priced at at $89,000 and available for your end of the year tax write off truck purchase!
This is a fully loaded 2023 6.7L HO Cummins Limited Night Edition with the Aisin transmission!
16,9xx miles currently
This truck has every option available on it ($108k MSRP - window sticker in pictures).
It also has $72,000 worth of aftermarket upgrades on the truck! (List on pictures)
It has the top of the line Carli Pintop suspension with full ALAS progressive rear springs designed to function with the factory auto leveling aid system seamlessly. Over $12k in just suspension.
It has $20k worth of audio upgrades, a high end trailer camera system, and built in Escort radar system, and so much more all installed by Signature Audio.
Full build, with no corners cut and ready for whatever you want to throw at it. Matte Stealth PPF - Fab Fours Bumper - 16k warn winch - 37’s. So much more.
Earlier this year SDHQ did a fine-tooth comb on it when it was in AZ and over $7k was spent on upgraded ball joints, drag links, etc. It’s in perfect shape.
Detailed Specs;
Fully optioned out 3.25 Carli Pintop Kit for OEM air ride truck including;
- Full progressive leaf spring kit ALAS
- Fabricated radius arms
- Low Mount steering stabilizer
- High mount steering stabilizer
- Front diff guard
- Ball joints
Remaining;
- Fab Fours front bumper
- Warn 16.5K winch
- Rigid fog lights (four total)
- Baja Designs LP6 Pro's
- Switch Pro 9100 switch controller
- Hard rolling bed cover
- FULL Stealth Matte PPF
- Synergy drag link
- SDHQ billet resi mounts
- Battery kill switch
- 20K on signature audio build (details in pictures)
Clean title in hand - no wrecks - never smoked in. The yellow vinyl is applied above the PPF and will be removed before sale.
What I like about the truck;
If you're going to have a tow truck for your big stuff, it might as well still be capable and VERY comfortable. This truck rides like a heavy 1/2 ton while boasts IMMENSE towing capacity. Being a loaded up Limited model the creature comforts are something to boast about. The upgraded audio, sound deadening, and built in radar system makes this truck the ultimate highway traveler. If you drop the camper off and need to make your way through some large trails the truck will certainly handle it with the 37's and top of the line suspension. It's not your typical overlander, but it is an incredibly well built and very capable large truck that is priced a large amount of money under what it would cost to even remotely replicate it... All in time to purchase so you can snag that big truck write-off on your taxes.
More pictures
More pictures
More pictures
Getting ahead of all the messages. The vinyl will be removed prior to being picked up. It was just recently applied, and applied above the PPF / leaves no marks.
Thanks!
MOLLYmaz
