22re Misfire (Unusual Symptoms)
Have you owned a 22re?
  • Total voters
    6
864runner
Hey everybody i have been doing reading and trying to solve this problem for months but I am getting quite confused. I will layout my post as organized as possible.
The Symptoms
-Somewhat hard to start ( When i first crank it over it will start then immediately die(unless I give it gas). I try to start again and it takes a couple more cranks then the first time before it starts, after it starts it is REALLY shakey for about ten seconds or until I get on the gas)
-I believe the previous symptom might be related to my others
-At idle there is a random misfire
-That same random misfire occurs under light load/cruising speed and creates a jerk
-Usually never misfires under heavy load
- Right after accelerating I let off and sometimes hear a blurb blurb blurb and maybe even a backfire high up in the exhaust. FYI I do not have a muffler ( Best way I can describe it is a stock car decelerating
right after being on the gas hard)
-I notice on the highway (I drive the same stretch every day) that sometimes I will have more power going up that hill the other day/ visa versa. Or I think weird I didnt have to downshift to 4th yesterday to keep it at sixty going up the hill
Attempted repairs
-New distributor, cap, wires, rotors, plugs
-Checked timing
-All new fluids around
-AFM Checked
-TPS checked
-Throttle Body Cleaned/Intake Plenum
-I HAVE NO CURRENT CEL CODES
-BOUGHT VEHICLE AUGUST 2010
-CHECKED FOR STORED CODES MONTHS AGO, CODE 7? THE TPS CODE
So I adjusted the tps, which was new by the way, cleared the codes never came back
-This is just what i can remember
The Vehicle
-1987 4runner 292,000
-22re rebuild 15,000 (Never saw paperwork but it pulls hard....for a 22re)
Update
-Checked the Ignition Coil today
Spec for Primary .5-.7 . Spec for Sec. 11,000-15,000
My Primary was 1.7-2.0 and Secondary was 14,000
The Question
I'm hoping I found the solution! I was wondering if anyone could chime in and tell me if my coil could be causing these symptoms?? Is being 1.0 off on the Primary a big difference? Any other components I should still check out? I would love nay feedback or any other ideas!?
Thank You in Advance, I bow to you toyota techs
Owyhee H
Many people have experienced a broken injector wire. I would suggest checking the continuity on your injector wires, although you only experience it occasionally then it might be hard to detect. Maybe measure the resistance to see if they are consistent.
Dont know anything about the coil....good luck
4xCoffee
