235/85/16 on stock 05 Tacoma?
Schattenjager
Well, I have a buyer for the Rover and he thinks my 235/85 BFG AT's are too sissy for him They are less than 1K miles old.
?: Can I mount them on a bone stock 05 Tacoma without tearing anything apart? They measure 31.7" according to BFG.
Soon I will get an OME lift for about 1.5 - 2" or so of lift.
They are currently on 8" rims and I have even aired down a little with no ill effects. 7" rims would be used at the same time as the lift, just to be extra safe.
What say you folks? I gotta make the swap this AM if I am going to do it...
:rally_guys:
nvprospector
They should work without any issues. I mounted 265/75 R16 on my taco with no rubbing. Here are all of the tire dimensions
Stock Tire
265/70 R16
Diameter = 30.6”
Section Width = 10.4”
Section Height = 7.3”
Tire I mounted without a lift
265/75 R16
Diameter = 31.6”
Section Height = 7.8”
Tire you would like to mount
235/85 R16
Diameter = 31.7”
Section Width = 9.3”
Section Height = 7.9”
As you can see, it should work without any problems.
crawler#976
...with stock wheels, no problem.
If you use any thing other than the stock offset, there will be substantial rubbing. The slightly narrower 235 would help some, but I still had to do some plastic trimming with a 2" lift and 265/75-16 mounted on 16x8 MB Rocker rims.
Goldenbora
