stewrafalo
Description
This Japanese compact camper has everything you need on a smaller scale. Nimble enough for a crowded parking lot or out on a 4WD road, this van is very capable and maneuverable. Hi/Lo 4WD system will get you where you want to go. Custom Interior build by Van Lab in Durango, CO in 2022. I'm selling this vehicle because we wanted more space (purchased a Ford Trans
The camper has an open feel, skylights and moon roofs fill it with plenty of light. Comfortable galley to hangout for 2 people on bench seat with adjustable table. Rock and roll bed converts easily and sleeps 2. Deploy the ARB awning and pull out the under-mount table from the rack and enjoy shade or cover from rain. Rear cargo area has ample storage, as well as the 2 cabinets in the galley. The hot/cold box is great for breakfast burritos or cold drinks, located right between the 2 front seats. Heat/AC and electrical all work well. The stereo and speakers are decent, with a temperamental tape deck (we use a Bluetooth transmitter). The turbo was added in 2020, the van is not fast but can maintain adequate speeds on the highway. It slows down considerably on steep grades/climbing. The body is in good shape with only a couple very minor rust spots. Original upholstery, seats, headliner and interior finishes are all in good condition. There’s an issue with the power locks while running (clicking noise) so once in the vehicle you have to manually lock the 2 front doors and the noise stops. All regular service and maintenance have been kept up. It was imported to the US in 2020 with 120km on the odometer.
135km (84,000 miles)
Custom interior build by Van Lab Durango (see attached build sheet)
Right hand drive
Interior
Power windows
Power driver's seat
Hot/cool box in console
Built in tea kettle
Multiple sun/moon roofs
Interior curtains
Espar heater tied to diesel line
Stainless sink with 5 gallon storage
Dimmable LED lights throughout
Galley cabinets with Dometic fridge
Large pull out cabinet/storage behind passenger seat
Bamboo counters
Grey coin flooring
Rock and roll seat/bed combo
Custom high quality cushions plus mattress topper
Lagun swiveling table (interior or exterior)
(100 AH) House battery system/starting battery isolator charging
12 blade fuse box
Battery monitoring system
USB ports and 12 V outlet
Exterior/Mechanical
Hi/Lo 4WD with locking hubs
2.8 3 L turbo kit- installed by North West Toys, Monmouth, OR
Front end rebuild kit
EGT exhaust gauge
Upgraded exhaust
New upper and lower ball joints for both sides
New front brake pads and rotors
New Inner/outer bearings and wheel seals
Custom HD Aluminum Radiator and thermostat
3” lift kit
Frontrunner Slimline II rack system with under mount table (4’)- $1700 value
Solar Panel
Full size spare mounted on swing out hitch for bike rack
Toyo Open Country tires
ARB awning
M meadow build
