$25 minimum bid: ACOPOWER All-In-One (3000W Inverter / Shore Power & Solar Charger)
geoffff
This is an ACOPOWER All-In-One (inverter/charger) unit that can serve as most of your vehicle's new lithium-ion battery electrical system! Functionality includes:
  • 3000W inverter
  • shore power charger
  • solar charger
  • remote display panel
Retails for $1300 ACOPOWER 3000W All-in-One
User Manual: ACOPOWER All-In-One User Manual (PDF)
There are a few minor scuffs on the case (see photos below) but the unit should work fine. (The ACOPOWER didn't quite fit under the rear seat of my van where I wanted to mount it. Then I decided to just go fancy and use Victron for everything.) Except for a bit of testing, this ACOPOWER unit has never been used. This all-in-one device needs a new home.
I'd like to get $300 + shipping. Note that weight and size are significant, so local pickup (Seattle, WA) is preferred. Shipping weight (with box, remote, cables): 26.5 lbs. Main unit dimensions: 18.2" x 10.6" x 4.2"
I've installed one of these. It's an easy solution if you don't want to assemble a bunch of other pieces. You only need some wire, a 12VDC fuse/distribution panel, and a 120VAC fuse/distribution panel. It also provides 12VDC when connected to shore power (without batteries).
The small panel acts as a remote to turn on the inverter and does a few other things.
jasper.mullins
