280GE Build
stjjames
Thought I would start a thread here as well.
This is my buddies rig, but he isn't the forum hound I am :sombrero:
It'll be a recreational wheeling / camping / hunting / DD rig - I myself fancy for camping as long as I can & often for a week plus, as far away from other folk & less capable rigs as possible.
He picked this rig up to replace his 69' S2A.
He desired a sealed cab (the LR leaked), with more interior room, for folk & gear.
Couple of Pics of the S2A ( the TJ is mine) ;
He picked up this 1985 280GE out of Texas. Inline six, four speed auto, VG80 transfer case, 4.88 gears, etc, for $5K - with a blown transfercase. He quickly squared the T/C away & had it road worthy. Slapping a fresh set of 32" Kevlars on it & proceeded to take it out on the trail, which was short lived. It hardly made it 200 meters before a rock punctured the gas tank & he was headed home in shame :p
He wanted to get in squared away, similarly to the S2A - so he could at least get it on the trail.
Best Before shot I have handy . . .
stjjames
We dropped it off at Those guys rods & Customs up in Bremerton. He has done a slew of work to my rig & decided, since he was particularly well versed in XJ's - he would be the right guy to fab some junk for the G. Aside from the frame, The G isn't a - huge - departure from an XJ. The goal was to get it trail worthy & armored up from the beltline down - without compromising the overall look of the G. From 50 feet we're hoping it all looks rather stock . . . ish.
First thing was to address the particularly low & vulnerable rockers. XJ style rocker replacements were chosen - though it was found there was considerably more reinforcing material in the G than an XJ - I guess that justifies some of the weight :coffeedrink:
Full cut away & weld in replacement, with a small kicker - to try & keep the tree's at bay :elkgrin:
Underside;
Flat Belly skids, an oil pan skid is in the works soon enough - potentially just a armored stock unit, with plate welded to the circumference.
The stock radiator was shot, so a (much cheaper than an OEM replacement :Wow1: ) Griffin aluminum unit was chosen as a replacement. custom mounts had to be made both on top & bottom.
Topside mounts, easy-peasy.
The lower mounts are tied in to the front crossmember, shoring up the whole front end.
stjjames
Gas Tank was definitely in need of some up-armouring after its ill fated first venture :D You can see it's tied into the rear bumper.
And speaking of the rear bumper.
In process;
And with the low-rider rear tire carrier - still looking for a matching wheel if anyone has one for sale :ylsmoke:
stjjames
Moving around to the front - we knew the front fenders wouldn't survive in stock form & were prohibitively expensive to replace - so Vince (the owner) opted for Defender ' trophy" style fenders.
In process;
Inside;
Looking Forward;
And Aft;
Antenna mount;
And done, minus headlights.
Strong!
Onto the front bumper.
He wanted a winch mount, up kicks to keep the rough off the grill & to be stout enough to slay wayward deer.
Top side shot, along with a better shot of the radiator supports;
Under side;
stjjames
And, his freestanding light bar. This may end up being tied into a roof rack / rub bar arraignment . . .
Mount & fender transition.
That wraps up Pat's work on it. The first day we got it back, we tossed the winch from my Tj onto it - I'm going to M8000's front & rear.
Oil cooler relocated (Pat actually did this)
We had to trim away both grill & supports abit - but with all of the reinforcement, these became mostly trivial.
And after relocating the 3 pointed star - so mean looking !!!
stjjames
Aaaand, with heads & turns - still waiting on the trim rings from RoversNorth.
He's gonna put the front flare, front mud flap thingy back on - to further it's stock appearance.
Though, in those pics you may have spied his dented rocker kicker . . .
Their going to have to be redesigned abit, using 3 tube supports, instead of 2 plate units. When we were flexing it out, he started to slip forward & gave it some gas, it tagged the tree with the full weight of the rig on two wheels :D
A proper first day home & way to christen a rig that will see a healthy amount of trail time.
I circled where his rocker hit the tree, haha.
That pretty much brings us up to date.
A roof rack, sand ladders, communication equipment ( CB, VHF & Ham radios ) are in the immediate future. Well until we hybrid cage it & toss 404's & 37's under it - I mean, for the cost of gears for this thing, we may as well buy a D300 & 404 axles - cheaper in the longrun, or so I'm trying to convince him :elkgrin:
mk216v
Der Chef der Fahrzeuge
Thanks - definitely more to come !
The owner is in Portland as well - we'll be making trips out to TSF & HooDoo soon enough. :ylsmoke:
TSF as in Tillamook State Forest?
I've been out there the past few weekends. :smiley_drive:
stjjames
Correct sir!
What trails are you guys running ?
All of the rover pics were out at TSF - I think it's the best place in the area & have been Biking, riding, shooting, hiking & wheeling out there since I was a wee welp. We normally go, FB5 - hit the rock pile, then do one of, or both of the Crushers loop(s), Rockyuphill, Airplane hill - now thats its open (the G can likely handle the filter, but will prolly pass on the main obstacle), can opener (again, the G will skip this - it's gotten nasty !), then the waterfall, which should be fun for the G ! We'll be heading out to Naches & of course the Rubicon as well ! And likely many gear laden camping trips in central Oregon !
I think the rig should be able to pic it's way through the upper crushers, in the dry.
Vince on Hogsback, even in the dry the lack of lockers denied him !
Trying to roll it on RockyUp(down)Hill - the G will be able to tackle it going up & will be a well suited & fun trail for it I think !
My rig - sure is pretty in the winter !
Anyhow, enough non-G photo whoring ! New G pics coming soon !!!
stjjames
Where exactly are those in TSF showing the Rover?
Ironically, Vince - the rigs owner - sold his sweet 92 Mk2 16v GLi to buy the rover & really wanted a red or white G.
In the above post I posted the trails they were taken on.
As for the first page pics.
Top of FB5
Random fire road, his quarter panel discovered a stump !
Back entrance to the lower crushers
RockyUpHill
FB5
mk216v
Perfect, thanks for the further detail.
Well, my red G is for sale if he's interested. :)
Back to the 280GE build!
flipstick
