2nd Gen Xterra Front diff issues?
ChuckB
I really like the 2nd Gen X's and have been doing a lot of reading on them. It seems the biggest weak spot is the front diff. I did a search but could only find posts that were a couple months old.
Is there an aftermarket fix yet? Or are most people swapping Titan parts still?
ChuckB
Thanks for the update. I need to keep a better eye on this topic. I wouldn't mind an X as a DD.
So is just just the extreme amount of torque that's exerted when the wheel with no traction catches traction that's causing the breakage?
Bergger
That is what I believe. It is true the Xterra has a very powerful motor. It' one of the many reasons we like our 2006 so much. I really think it is a superb vehicle. I agree with the above post that it has a lot to do with your driving style. If you are hard on the gas and you pop a fast spinning wheel off the ground there is always a possibility that when it makes contact with the ground something could give. In the Xterra's case it appears to be a half shaft. I do drive conservative off road, with my Tacoma as well, and we've got almost 18k on our Xterra with no issues. The only thing we had to get replace so far was a tire pressure sensor that went bad.
madizell
Probably the one item on the vehicle that I would not replace if it failed. I simply can't find a redeeming feature in the TPMS.
Bergger
It helped my wife last week. Sensor went off and she checked the tires and found a nail in one.
jesus m anderson
