2UZ-FE motor part out
dyogim
I have a 2UZ-FE for part out. It's from a 2000 Toyota Tundra 4WD. Has about 175K miles on it. Valve stems seals were recently replaced. Blue smoke was coming out of the muffler during start-up. After changing seals, smoke was still there. Figured, I would rebuild the whole motor but, decided to replace with a used one. Reused the intake manifold/plenum and throttle body. However, I have the intake manifold/plenum and throttle body from the donor motor but, it's damaged.
Incomplete motor: $350. (accessories, wire harness, some hoses not included)
If parted out....
Heads: $175 for both or $100 each side.
Short block: $200
Let me know if you are interested in anything else...
Buyer pays for shipping from Antioch, CA 94509
dyogim
Do you have the AC clutch assy?
Sorry I do not. Recently sold it. Only accessories I have left is the alternator.
Parts no longer available:
Coils
all plastic timing belt covers
throttle body is damaged
upper part of intake plenum has some damage
some of the coolant hoses/pipes have been sold.
Goldenbora
