Okay, probably a newbie question but the search function has let me down and google/RV forum searches are just not coming up with what I want, I am in no fashion going to install a another outlet on the outside of my van and run an extension cord between the two.
What I want to do is install the inverter out of the way and tie it into the vans existing AC electrical system and have some kind of selection switch, be it manual or automatic to be able to switch between inverter power and shore/generator power, and of course to be able to use the AC system when boondocking. I have a three battery bank and 200W of solar, however I have no thoughts that it will run the air conditioning for any amount of time. However I do want to run the microwave and entertainment system without hooking up to power.
The van is a 1991 Airstream B190 so the current electrical system is a bit dated, I would have no problems replacing the current distribution panel as I have been planning on installing an updated PowerMax or Iota converter. I am assuming there has to be some way to isolate the converter when using the Inverter or there would be a loop.
Thanks!
Thanks!
