4wd Converted Isuzu NPR Rhino Camper Conversion on VanCamper
JLee
I talked with the seller on Facebook for a while, looks pretty slick - extra info below:
The only differences in the ad and now are it's on steelies with 35x12.50x17 Nitto Grapplers, it now has 400w of solar, 300ah of Lithium batteries, and the mini split is installed.
The parking brake handle is now the transfer case selector. There is pinion mounted discs that retrofit onto the axle. Never really needed it so I never did one. There is a fresh tank, 6gal, with room for a 30gal under the floor. The black tank is actually part of the toilet so it takes some complications out.
The toilet is under the bench next to the couch. I'll get some pics of the inside when I get home in a bit. The shower has a drain built into the entry with a slope, it's under the carpet. The carpet pulls out for use of the shower
The toilet is meant to come out to dump the poo and refill the water tank. I built the bench to be the same height at the toilet so you can use it in place. I put these in every build I do, it's the closest thing to an actual toilet. Flushes, no smell, and you can carry it into a bathroom and dump it.
The transfer case is a two speed unit. It's a big beefy boy from an International medium duty truck.
