4WD Isuzu Turbo Diesel Camper
TrailheadPDX
1990 Isuzu Rodeo Camper. 4WD, Turbo Diesel, 20-25MPG, 42,600Miles!
UPDATE: NEW EBAY LISTING
https://www.ebay.com/itm/153336663813
This JDM imported, RHD, all-fiberglass camper is one hell of a rig. Featuring the ultra-reliable, strong running Isuzu 4JB1 commercial turbo diesel motor, it will provide 20+MPG cruising. Lots of power from an economical 4cyl diesel, very capable 4wd, lots of storage, comfortable sleeping setup, etc. It's really a special camper and will make an awesome ski resort basecamp this winter. Truly a 4 season adventure rig. Waaaay cheaper than a Sprinter, more room than a Westy, Stronger engine than a Hiace or Delica. Clean Oregon Title.
The Details
Appx. 20' long and 6' wide, it is easy to maneuver and park. Lives larger than its footprint.
4WD with manual locking AISIN hubs
Turbo Diesel Isuzu 4JB1 engine
Manual 5 Speed Transmission
Avg 20-25MPG cruising!
Features:
Seat belts for 4 adults
Sleeps 4+
Recaro seats
Large Electrolux fridge/freezer combo
Suburban 6 gal water heater
2 Burner stove
Dual Propane Tanks
Independent Heater System
110v shore power
Shower room
25Gal Fresh Water Tank
6 Gal Hot Water Tank
40 Gal Grey Water Tank
New:
ARB Off-road bumper (winch ready)
LED trail lights
Rubber floor
Fantastic Fan
www.trailheadmotors.com
TrailheadPDX
The A/C is probably due for a recharge. It is not very icy. Both the HVAC heat in the cab as well as the dedicated heater in the camper blow very hot. The HVAC from the head unit of the truck can be directed to the cabin using a control dial near the shower room. The dedicated heater is thermostat controlled and runs off propane. The refrigerator is 3-way. Works great off 110v and propane. The refrigerator is not currently working via the 12v circuit. However, if 12v is supplied direct to the refrigerator from a separate 12v supply, it works great. My suspicion is that there is either a bad 12v positive or a bad ground in the circuit and if a new set of 12v wires were run from the fuse panel to the unit, it would be back up and humming. Plumbing works well. Propane tanks and regulator are 1/4 tank since new. No leaks anywhere. Fiberglass is in great shape.
jesus m anderson
