4x4 Camper for sale PRICE REDUCED!
garybo
2003 Mitsubushi FG chassis with overland camper
Price is reduced to $65,000
The rig is near Phoenix, Arizona, USA
It has no known defects.
It's with pride that we offer this famous overland camper for sale.
Kim and Don Greene built the interior using their international experience as a guide. The shell was commercially built and mounted on the chassis by Unicell to meet all US highway D.O.T. regulations. Most custom campers are not approved for highway travel. The walls are insulated with two inches of polyurethane and foam block, plus the fiberglass, plus 3/8" plywood.
The Greenes have taken this camper from the arctic to the antarctic, through parts of Africa and other countries. The camper and truck are so well built that nothing has broken. Everything still functions well.
The Fuso FG is a commercial 4x4 truck, not a consumer truck like Ford, Chevy or Dodge. The components are designed for long term use. The camper is set high off the ground. The cab over engine design and high camper give the unit great approach and departure angles.
We are moving to another phase of our lives and are not planning on international travel as we originally thought.
Up front, let me say that this rig is designed for best performance on dirt and gravel roads. We get 10mpg on highway and 12mpg off highway. The 12mpg can be up hills, on corregated roads, pothole roads, forest, desert and mountain roads- this is where the rig functions at it's best.
Travel blog at www.questconnect.org vehicle site lower right corner
Rig pictured on cover of book "Americas Overland", by Greene and Greene at www.americasoverland.net
Let's look at the HIGHLIGHTS for you to compare to another rig:
It has been to 30+ countries, traveled 140,000 miles.
Fuso shops in Mesa AZ and Salt Lake City have inspected the frame and found no damage or problems.
bumper to bumper length 21'
professionally made and mounted cabin
2" insulation
one piece fiberglass cabin
4x4
turbo diesel engine
fixed queen bed
fixed dinette
8.5cuft frig/freezer
133cuft storage- now stop and carefully compare this amazing fact; it is all easily utilizable storage, sized so
that one does not stack storage boxes
This is a one piece molded fiberglass cabin, professionally made and mounted to the chassis by a company that
puts cabin/chassis rigs together daily
Outside storage 51.4 cu ft
Inside storage 72.2 cu ft (kitchen 22', hanging clothes closet 3.5' long, 29', other 20')
Flat shelves 7.2 sq ft
Bed 60x80
Inside hight 7'
Frig/freezer 8.5 cu ft
Bumper to bumper length 22', 133" wheelbase, very manuverable, fits in an ordinary parking space.
CHASSIS
2003 Mitsubushi Fuso FG
overall length-22'- park in an ordinary parking space
wheelbase- 133"- great turning and parking
front axle 5500lb rating, Rear axle 8600lb rating
suspension- custom Deaver springs installed 2013
shocks- Rancho 9 position, 999117 front, 999113 rear, 11/12/12
tires- 16" wheels; LT235/85R16E Cooper Discoverer ST MAXX x 8, bought June 2011 at Discount Tire
start batteries- 11/15/12; 5yr warranty
engine- 4-cylinder in-line, water-cooled 4-cycle diesel; 4D34T3; direct injection; OHV; 145hp; 275ftlb torque
transmission- Aisin M035A4; automatic; 4spd plus overdrive
CABIN
body dimensions- 7'8" H, 8'W, 14'L
inside height 7'
over bed sit up height 30"
wet bath 7'H, 3'W, 3'D
double pane windows
insulation roof, walls: 2" sprayed in polyurethane + 3/8" marine plywood + one piece molded fiberglass shell +
inside luan finish wall
ENTRY DOOR/ OUTSIDE BAY DOORS
side entrance
all doors 2" insulation
WINDOWS
Parkin 8600 double pane
KITCHEN/ DINING
Dometic Tundra T80 frig/freezer 12v/110v 8.5cuft (Danfloss compressor);frig 6.5cuft
Atwood Wedgewood Vision 2 burner propane cooktop
double sink
fixed dinette table (34x17)
kitchen flip-up shelf 20x12"
kitchen drawers are tongue and groove
BED AREA
fixed bed (60x79), thick mattress with pillow top
storage cabinets at foot of bed
BATH ROOM
wet bath
Thetford cassette toilet (C-200 CS D3)
INTERIOR STORAGE total 82.2cuft
kitchen 21.9cuft, includes large pullout pantry
other inside 31cuft, includes floor to ceiling chest of drawers
hanging clothes closet 29.3cuft, 3.5' long
flat shelves 7.2sqft
EXTERIOR STORAGE total 51.4cuft
TOTAL STORAGE 133.6cuft
ELECTRICAL
30A shore power
2- 258Ahr AGM Lifeline batteries (new 2012)
630 watts solar panels
Morningstar TS45-MPPT charge controller
Bogart Trimetric 2025-RV battery monitor
Magnum 2000w MS2012 sine inverter
LED lights except in hanging closet
HVAC
Webasto Air Top 2000 Diagnostic diesel air heater with remote temp sensor
Dirna Bycool Camper evap cooler- easily works boondocking on 12v; drops temp 15 degrees
Fantastic roof fan/vent
2 Caframo wall mounted fans
PLUMBING
60gal fresh water (inside)
25gal gray water (outside)
Emerson Insta hot in kitchen; takes about 4min
Stiebel Eltron DHC 3-1 insta hot in bath room;
Nature Pure sink water filter
Shurflo Whisper King model 2093 water pump
30 lb propane tank (7.1 gal)
MISC
All maintaince is current and have records
Viair air compressor
propane, methane and CO2 detectors
propane tank inspection 8/21/12
have new unused computer boards for evap cooler
6/11 8 tires, Cooper 235/85R16 Discoverer ST Maxx, now 10/32 from 18/32 tread after 38000mi; free rotation at
Discount Tire
7/11 Webasto Air Top 2000D air heater: total rebuild and add wall thermostat
7/11 new evap cooler filter and rebuild fittings on tank; the filter can be rebuilt with cooler mesh from Home
Depot.
8/11 Magnum MS 2012, 2000W sine wave inverter with remote display; Trimetric battery monitor; Morningstar TS45
MPPT solar
controller; 2- 195 watt solar panels added, totaling about 500 watts solar
8/11 valve adj; flushed/ new coolant; flushed/ new power steering fluid, brake fluid
9/11 new radios and Sirius/XM in cab and cabin
9/11 new shower head/hose
9/11 new starter
11/11 driver locking hub, all hub bearings and seals replaced at 111000mi
filters for transmission, fuel, air at 128,557mi
3/12 replace all bay locks with same key, new main door lock
7/12 2- Caframo wall fans
10/12 transmission filter replaced
9/12 Rancho 9000 adjustable shocks
11/12 start batteries, 5yr warranty
12/12 house batteries 2-8D, SunXtender from Concorde
12/12 new solar roof fan to ventilate behind frig
1/13 custom Deaver springs for better ride; it sits level, corners without lean
8/13 all new wheel nuts; wheel rotation every 3-5000 miles.
12/13 front end alignment; all front end components tight and good condition
We just spent five weeks in 0-20 degree temps in Missouri. The insulation and heater allowed us to remain
comfortably warm.
mog
Kodiak Buckaroo
Interesting, so it's a Unicell Dry Freight cube...did they modify it for you and add the windows/cargo areas, or was that done after the fact?
http://www.unicell.com/UnicellVanBodies/DryFreight.aspx
I believe that Don & Kim Greene has Unicell custom build the 'box' for them.
More info here: ExpeditionVehicle1
Here: ExpeditionCabinBody.pdf
and here:ExpeditionVehicle2 (please note this is their expired for sale page and does NOT contain a price, so "not stepping on" this thread)
garybo
Unicell, from this rig's experience, builds a pretty indestructible 'dry freight box'. The Greenes added the indestructible, very functional interior. Everyone's needs are different- we, being full timers, wanted insulation, storage and a very functional kitchen for daily use. Cooking and eating outside in various bad weather and bugs wasn't for us. Other's priorities will be different. Take a look at Unicell's site if you want to start from scratch. If you want it all put together, proven, and now, then let me know. Of note is the 8.5cuft frig, 3.5' hanging closet and I'll put a couple of pictures of unique storage areas:
garybo
Looks like the floor to ceiling storage area didn't get posted correctly- my fault. Here it is, and bath room/shower, and storage under one booth seat, water under the other:
iStan814
