G35Vortec454
**************** PRICE REDUCED!!! **************
Price: $42,000
More info:
https://inlandempire.craigslist.org/cto/d/san-bernardino-4x4-class-motorhome/7634323794.html
Note: Before I decided to post it for sale, the final thing to do was the paint job (planned was the Air Force One livery, see photo); now, it'd be for the buyer to decide the paint job.
For Sale - $55,000 obo; please respond by Text only; Text me for specific detailed/closeup photos.
Chassis: Ford E350, 158" wheelbase
Engine: Ford 7.5L / 460 ci EFI
Transmission: C6, 3-speed Automatic
ODO Miles: 52,200
Front Axle: 4.30:1 Dana Spicer Super60 Monobeam, Wide-track
Rear Axle: 4.30:1 Spicer S110, Limited-Slip
Transfer Case: NP205, Divorced, Cable-shifted
Body: Class A Motorhome, Rexhall Vision Molded Fiberglass
Suspension: 7.5-inch Lift, Adjustable caster/camber, Front Coil Sumosprings, Rear Leaf Air Bags
Tires: Goodyear G670 RV, 245/70R19.5 on dually wheels
Fuel Tanks: 35-gallon tank and 20-gallon reserve tank
Propane Tank: 9 gallons
Water Tank: 30 gallons
Waste Tank: 30 gallons
Overall Length: 23 feet
Width: 92 inches
Loaded weight: 12,000lbs
Electrical –
Extra Gauges: Digital- Fuel Pressure, Engine Vacuum, Engine Temp, Transmission Temp, RPM
Dash-mounted Clock, Weather Sensor, In/Out Temperature, Humidity
Dash-mounted LCD monitor for reverse backup camera, push-button forward "watch behind"
250A High-output Alternator, Voltage/Current charging digital meter on dash
Adjustable voltage charging on/cutoff digital controller on dash
3000W Xantrex Prosine Inverter, with 120A 4-stage charger, remote panel on dash
Morningstar Sunsaver Duo solar charge controller with remote panel on dash
420AH Battery Bank
400W Solar Panels
13.8V Constant-voltage 10A receptacle with USB Fast Chargers
240V/120V/12V Inverter Generator, 7000W continuous power
17,500lbs Electric Winch with Synthetic Rope
Onboard Electric 150PSI Air Compressor, with 1+5 gallon tanks
High-power auxilliary electric fans, radiator-temp/AC controlled
2-step Kwikee Electric Automatic Door Step
Appliances -
Dash Air-conditioning
13,500btu Dometic Roof Air-conditioner
16,000btu Suburban Furnace Propane heater
5-gallon Propane Water heater
Norcold electric/propane refrigerator-freezer
Dometic Microwave Oven
4-burner Propane Kitchen Range/Stove, Oven
Double-bowl staunless kitchen sink on base cabinets
Conveniences -
Full bed - with memory foam topper, down pillows, sheets, comforter; sleeps 2 adults
Dinette seating, can be converted to sleep 2 small adults/children
Bathroom – water-flushing toilet, shower stall, and roof vent
Fantastic Vent Automatic Intake/Exhaust Fan, Rain sensor, Remote control
15 Interior cabinets/drawers, with a small wardrobe closet
Sony 7.1ch Soundbar, mounted overhead, 200A Subwoofer
Mede8er / WD-Play 6-channel Media Players
Samsung 32-inch Smart/WiFi TV
Miscellaneous -
6 Exterior compartments(3 Passenger side - Generator, Propane, Compressor; 3 Driver side for Tools)
Vehicle-recovery gear toolbox, front bumper-mounted
2 Lund toolboxes, rear bumper-mounted
4G LTE Outdoor Router/WiFi on roof, with dual LPDA directional antennas, manual rotation
Included - 2 new/unmounted Bridgestone 245/70R19.5 tires, Spare new 250A Alternator
Original Motorhome Owner Manuals
USB-drive / paper documents - Notes on custom installs (wiring diagrams, drawings, etc.)
