Burlydirtyhippy
Chambon
****SOLD****
We have been dragging our feet, hard to let it go. It is serviced and ready for adventure, needs nothing. Oil and filter changed every 5k miles. New tires. We feel it is the perfect overland unit for a couple. Same footprint as a regular body van but so much more interior volume than an extended body. Able to negotiate tight trails and tight Latin American city streets. The only setup to camp is swivel passenger seat, put up window screens and pull out entry steps. On travel days momma can slide back and use the toilet and grab a snack while you are crunching miles. Average just over 10mpg.
2016 Ford E350 4x4 Expedition Unit $87k
31k miles, put in service August 2018, chassis warranty from Ford through 36k miles July 2021
-titled as an RV 2016 Ford House Car
-138” wb, 10’ Supreme Mfg Spartan Box
-same length and width as an RB, more interior volume than an EB
-10’2” overhead clearance(roof boxes no longer installed)
-73” interior height
-78” interior width
-10,000gvwr, dry weight approximately 8000lbs, wet fully loaded for travel with occupants +-9500lbs
-6.8l V10 305hp, 420lbft
-6r140 6spd auto
-SCT tuner
-Ujoint Off-road 4x4 conversion
-Dana60 RSC upgrade, 4.56 Detroit Trutrac
-Dana70 Rear 4.56 factory l/s
-6” weight spec springs
-rear air bags, cabin gauges and control
-Ujoint onboard Air
-Aluminess front bumper
-Fox shocks
-KMC Panzer wheels 17x8
-new 35x12.5 17 Bfg Ko2s (5)
-(2) 11-lb external mounted propane tanks
-manual windows, mirrors and door locks
-Rostra cruise control
-Ritchie dash mounted compass
-Pro Clip phone holder
-Pioneer AVH head unit, Bluetooth, Backup camera
-Wet Okole Seat covers
-swivel base on passenger seat
Camper Box
-Full size memory foam bed
-20 gallon fresh water tank(we carried (4) 5 gallon garafons in the “garage” as well)
-Shurflo 3.0 Revolution fresh water pump
-spigot at rear doors for shower/rinsing
-Suburban 2 burner gas cooktop
-Isotherm CR130 fridge
-Propex MKll furnace
-semi-composting toilet, works well and the wife uses it exclusively and I do for #2s, urine needs to be dumped twice a day, solids need dumped every 4-7 days
-Lagun table
-(2) Maxxair ceiling Fans 10 speed intake/exhaust
-Caframo small bed mounted fan
-multiple 12v/usb power points
-Xantrex PROwatt SW 2000w inverter
-Arctic Tern windows with screens and shade
-flush mount LED lighting
-Custom built Interior cabinets/shelving
-Cork flooring
-OBX Remix shade awning
-1.5” foam board ceiling insulation, .75” wall insulation, .125 floor insulation
Electrical
-(4) 100w Renogy Panels
-(3) 100ah Renogy Pure Gel batteries
-Blue Sky SB3000i solar charge controller
-Blue Sea manual disconnect switch between house and start batteries
-Blue Sea 12 circuit fuse panel
-Noco Genius Gen1 10amp onboard battery charger
-Brophy aluminum entry steps
-carbon monoxide alarm
-MTI propane alarm
Negatives
-light pinstriping on the box and wheels from tight trails, we have not beat on the truck but have used it for its intended purpose, regardless it cleans up extremely well and looks great
-tire pressure warning light is always illuminated, non-adjustable tpms
-check engine light is illuminated for evap leak or loose cap, the evap system is relocated to make room for the transfer case, I believe it’s from the extended lines and faulty reading.
photos: https://www.icloud.com/sharedalbum/#B0W5Uzl7VTLk35
-78” interior width
-6r140 6spd auto
-SCT tuner
-Ujoint onboard Air
-Fox shocks
Camper Box
-Lagun table
-Cork flooring
Electrical
-MTI propane alarm
Negatives
