4x4 Equip Combo Shovel & Case
flyingwil
Sierra Expeditions now has the 4x4 Equip Combo Shovel & Case's in stock.
The ORIGINAL and unique 4x4 Equip Combo Shovel takes away the hassle of trying to carry a long handled shovel inside or outside your 4WD. An easy to use three piece shovel.
Simply un-screw the long handle at the threaded joint and store it conveniently away. By attaching the supplied 'D' handle it now becomes a useful spade.
The high quality Combo Shovel is built strong for hard work and consists of a heat treated steel blade, multi-core, steel reinforced fiberglass handle, heavy duty "D" handle and steel joining sleeves. It has become very popular with four wheel drivers who at times may require either a long handled shovel or a short spade but don't want to carry two separate items, and is easy to carry in any vehicle.
Included is a Combo Shovel Bag and is the ideal accessory to store your Combo Shovel, keeping the inside of your vehicle free from dirt. The 4x4 Equip Combo & Compact Shovel Bag is designed to store your 4x4 Equip Combo Shovel or Compact Shovel. Three different compartments separate the D Handle, Long Handle and Shovel keeping dirt and grime away from your vehicles interior. The Combo and Compact Shovel Bag is built using hard wearing materials and has a carry handle for ease of use.
Technical Specifications:
Long Handle Shovel Length:56.29" (1430mm)
D Handle Shovel Length: 38.18" (970mm)
Minimum "break down" Length: 30.31" (770mm)
Blade Width: 7.6 " (193mm)
http://www.sierraexpeditions.com/index.php?l=product_detail&p=2181
Goldenbora
