Hello everyone
I've had an idea going around in my head for quite some time but I'm hoping for a bit of help and advice. I owned this hiace when I was 19 and travelled all over New Zealand in it. It was an excellent vehicle, really reliable and super economical with a 2.8 diesel and manual transmission. It was also 4wd with low range so it performed fairly well off-road considering its poor approach and decent angles.
What I'm dreaming of this time is something slightly more capable, solid axles with leaf springs front and rear, a bigger engine, locking diffs and hopefully slightly more internal space although the hiace was fine. So the idea I've been throwing around is getting one of these:
Its a Toyota Dyna Van. From what I can tell they come in 3.0, 3.4 and 4.1 non turbo, mechanical, diesel. They have leaf springs front and rear, with a beam front axle. They're roughly the same size as a hiace but with a full chassis they are capable of carrying much heavier loads.
My idea is to remove both the front beam axle and rear diff and replace them with factory locking diffs from either a 70 or 80 series land cruiser depending on which width is more suitable. Obviously this will involve changing the diff mounts to suit the factory leaf springs. From what I can tell the vans gearbox is a very similar unit to that used in land cruisers too, so I'm hoping I can swap the transfer case onto the back of the vans gearbox. Custom driveshafts will be needed.
I don't believe these vans (or the truck verisons?) were available in North America so I'm not sure how much help I'll get here, but it seems like a lot of the ford a Chevy vans get converted so maybe it's a similar idea.
What I need help with is:
-1. Will the land cruiser diffs be strong enough to carry the weight of the van loaded up as an off grid style camper?
-2. How would I go about changing the steering linkages?
-3. Am I better to mount the diffs above the springs or below?
