Out of Bounds Off-Road Trailers Weekend Out
Located in Colorado Springs
Purchased Summer of 2021
All steel construction
4’ x 6’ enclosed trailer with a side access door and swing out tailgate passenger side
Max-coupler hitch, tongue jack
Heavy Duty Timbren independent axles 6x5.5 bolt pattern 3” lift (Toyota 4runner/Tacoma)
12” Electric brakes 7 pin connector
LED break strip lights
2” Rear hitch
3 doors with like keyed compression latches
Custom Lining coating on all surfaces (lifetime warranty/brick & mortar in CO Springs) https://customlinings.com/
2 Pair of leveling BAL C jacks
Spare tire with strap mounted on top
Open basket 4’x18”x18” center spare tire mounting loops
E 4’ rail strap down system 8 tie down clip placed 10” above the trailer floor
Tongue box (aluminum) (uws01065) black 6.3 cu ft.
Step sides 4 corners and reinforced hand built fenders
Drop down tailgate table
Telescopic tent rack 1x2 ribs and frame with lifting scissor jacks
Fixed awning mount driver side
Propane mount x2 back quarter panel mounted
Pair 11 lb. propane tanks
21 gallon water tank, fill, pump, plumbing, wired to a switch and plug in
30” walls Side door 19” opening shore power and solar external connector
Pair Roto Pax 3 gallon fuel tanks mounted
Add on’s
Yakima Slim Shady 8’ awning
Ark XO500 trailer jack
Joolca HotTap V2
Thule Autana (annex, condensation mat, boot holder, winter insulator)
2X Heavy duty 500lb drawers (extruded aluminum & HDPE)...the drawer (pictured in the 4 runner) is in the rear & the top has been modified to slide-out
4 total matching wheel/tire set
Homebuilt Colorado Trailer Title
Pics include before/after 3" lift
Additional pictures upon request
OBT - Out of Bounds Off-Road Trailers
OBT - Out of Bounds Off-Road Trailers. 60 likes. Locally owned and operated off-road trailer company.
www.facebook.com
2” Rear hitch
Add on’s
Joolca HotTap V2
