java
i want an axle with 6 on 5.5 bolt spacing.
i can get an off the shelf 5200lb one with 12x2" brakes that has the correct pattern or a 3500lb axle with 10" brakes and adapters.
is there a huge weight different in the 5200 vs 3500lb axles? im trying to keep the weight down as much as possible, the prices end up being almost the same, when the adapters are added in.
