5th Gen 4Runner gets Klima scheel-mann seats
If you have a 5th Gen 4Runner and are considering our scheel-mann seat mounting system, the result is not a full manual setup. In order to be able to utilize the 4Runner's seat rails we needed to keep the fore/aft motor in place which means figuring out the wiring and the replacement switch for the motor's function. We think we nailed the looks.
The seat motor, if you do not have seat memory, is just a two wire motor (ground and power) so it's function was easy to integrate.
Now if you have seat memory then it means you have a 4-wire connector. We do have the connector solution for that BUT do keep in mind that you will lose that seat memory function by doing this seat upgrade.
seth.c96
