2021 5x8 custom built v nose. Started as a custom Georgia trailer, same people that make Spartan trailers. Rear ramp door with levers. Lift kit. Extended tongue. Upgraded jack with jacks in rear for stabilizers. Upgraded trailer wiring to 7 pin with box. Upgraded coupler.
Ladder rack. Aluminum 15 wheels with 31” AT tires. Full sized spare and mount. Roof coated. Enclosed water heater, Camplux set up for city and container water. 12v pump mounted inside box also. Rear hitch.
Electrical. 2- 80ah agm batteries. Onboard charger. Solar wiring. Fuse panel. Switch panel in front and back. Both with usb and sockets points. Bluetooth radio with 4 Polk speakers. LED lights inside and outside awning lights. Max fan with rain snorkel. 115v window ac unit that goes in and out easily.
1” rubber flooring. Custom cabinets with hidden battery boxes.
Had Chinese heater installed. Coded out due to lack of use so took it out temporarily.
Have a 8’x8’ main awning. A Ironman shower awning. Wall mounted propane tank. Hose is enough to hook up water heater while leaving tank in place.
Batteries still hold charge. Tires are great shape. Trailer pulls amazing at any speed and handles some trails with ease. Selling due to health issues. I have rhino liner to coat front v nose but Haven’t been able to yet. But will throw in the entire gallon if want.
$8000 obo. Need to move. Most progress photos are on here under build.
Northeast al.
Also we pulled it with a lifted Jeep JLU and it didn’t know it was there at any speed.
Also it’s strong enough to haul two 150# kayaks if needed.
Northeast al.
