Don't do it. I guess that's piling on but I can't help myself. I have a 3" lift on my '01.5 Dodge, 2-series, and it's not much but enough for my purposes. Understand that it's 3" of lift WITH the weight of the camper on the rear suspension; the loaded rig sitting more or less level. It's about a 5 inch lift on the rear with no load. Why 3"? It was a long, decades in the making process after doing a lots of lifts on dozens of Jeeps, a Scout II, a diesel Scout II Traveler, a couple Land Cruisers, various Pickups including a '73 J4000. I never did a lift for the 'look'. Always it was to not let the tires rub, get over bigger rocks without dragging something under there,
have more suspension travel or, in the case of my Dodge to get a tiny bit of lift for whoops on trails like the Mojave Road or the White Rim Trail so the approach, break over, and departure angle would allow me to continue without dragging.
There are a few concepts to consider:
1. With a truck camper you want to have your overall height as low as you can. A low center of gravity is best on poor roads or trails.
This goes directly against the need for-
2. slightly taller and wider tires that you can air-down and back up, especially if you are a 'sand-man' like me.
3. The stock suspension is the best when you get way out there, like in a 3rd world country, as it has been meticulously tested (sometimes by consumers themselves) and we hope all the flaws fixed. The farther you get away from stock springs, the more woe you will have somewhere down the road.
4. In Mexico, Central Amerique, and Sud Amerika most of the main roads are passable by any old Toyota anything and dually 2 ton box vans. Your track width will fit right in.
5. For expedition use, you want your camper to be as narrow and least tall as you can. And x-out the outrigger jacks.
6. If you really want to spend your money on something that will upgrade your rig try these:
a. Limited slip type diffs, front and rear.
b. Have an air up system on board.
c. take a lot of recovery gear and a winch. Chances are you will be jerking some native out of a ditch, not using it yourself to self-extract. I used one of my winches to pull a friend's chimney down after the 1971 Sylmar Earthquake in L.A.
Several of us on here have written extensively on how to make your TC rig survive months on the road in a 3rd world country. Do the search feature for more info. jefe
