Jredone
Compound Turbo 12 Valve Swapped F350 with 2022 Bison Overland Flatbed camper on 37s, King 2.5 coilover 4 link front, alcan/icon 3.0 rear
40,000 miles on motor
25,000 miles on entire drivetrain (trans, axles, 4.10 gears LSD, NV5600, np205 tcase)
223k on odometer
We’ll Start with an asking price of $105k
(Truck and camper will be sold together, not seperating)
**registered and insured as a Motorhome**
Located in Millington, NJ
You Never know what an appropriate asking price is with this stuff. I’m well over 150K+ in the build and unfortunately you never get that money back in this game. All receipts for parts, work, etc. will be available for the buyer.
Due to a growing family and less time to spend “off grid” playing on bicycles, a more Road oriented/RV park type rig is necessary
So on that note I am Open to trades for LARGER Vans with room for bicycles, class B+, C’s such as Winnebago ekko, coachmen crosstrek cross trail 20xg or similar with “garage space” to store bikes inside
This truck will not be for everyone so please read thoroughly if you’re interested and leave the poor comments out of the thread if you’re not.
Feel free to privately message me with any gripes, concerns, complaints on pricing, etc… also feel free to ask any relevant questions you like in the thread and I will do my best to answer
It’s Loud, it’s fast, it’s high, it’s manual, and it will not pass any type of smog inspection, so California need not apply. Although it does run very clean on biodiesel.
It will run forever if properly maintained.
Parts are available most everywhere.
Will run on all the diesel here in the US along with the questionable stuff outside of the country. For that reason there is a FASS fuel system in place for its filtration and water seperation and ease of access and serviceability
Very easy to get back up and running with common 12 valve knowledge if there was a break down
The focus of the build is around Mountain biking off grid. Designed to be as reliable as possible and rip fire roads comfortably and fast more than ride pavement all day long. Please keep that in mind if you’re inquiring on this rig
• 04 Ford F-350 Lariat leather Crew Cab 4x4 Long Bed with Black Powdercoated Custom Flat Bed with Built in Gooseneck under camper
• Rust free rig. Most of its lift spent in Idaho. Garage kept in winter, primarily used summer and fall
• 5.9 12 Valve 64 over 75 Borg Warner Compounds, Swap Was done in 2012 With 165k on the Odometer Before it Was Fully Rebuilt. Every Wear item Changed on Whole Truck... Down to Weather Stripping on Cab.
• 07 Harley Davidson Front End Conversion with •Billet badges Cummins Ford emblem.
• No Check Engine Lights
• Color Matching (Black Obsidian) 08 Mirrors
• Perfect Cream Leather interior
• Cover king Molle seat covers protecting the leather
• Two rear seat deleted for in truck bicycle storage (factory rear seats will be included)
• Motor fully rebuilt around 40,000 miles ago by Jefferson State Diesel
• Fire Ringed Head by Big Twin Diesel with Built Head Mild Cam, 4k gov springs
• KDP mod
• ATS 3 pulse exhaust manifold
• One piece keating design works valve cover, tappet cover
• 60 Lb Exhaust Springs so The Head Won't float When Using Exhaust Brake
• Bored .30 Over and sleeved at rebuild
• ARP 625+ Studs
• Fleece performance coolant bypass
• Mag-Hytek rear Dif Cover
• Amsoil Full Synthetic Oils Throughout
• 25000 miles on transfer case, steering box, 6sp NV5600 with Short Throw Shifter and Expansion Coolers
• Pac Brake PRXB Exhuast Brake
• Quad Pillar autometer gauges- Boost, Pryo, Fuel Pres, Trans Temp
• Protec Boxes Under Flat Bed
• Arb front bumper
• Arb twin compressor
• Bushwacker fender flare, no rubbing
• Come up 16.5k synthetic winch
• Factor 55 fairlead
• LED projector head lights
• rigid led back up lights
• Rigid led amber driving lights wired to factory switch
• Baja designs lp9 fog lights
• KC gravity roof mount light bar and roof rack
• KC side mount light bars driver and passenger
• SPOD bantam switch panel to control it all
• New dual red top optimas
• Noco on board batt maintainer
• Noco onboard waterproof plug for maintainer and block heater
• FASS Fuel Class 8 Semi Truck System
• Amp Full Length Auto Steps
• Every Wear Item In Drivetrain Replaced around 25,000 mi ago
• Kenwood Dash Cam With Full Time On Switch Wired
• Kenwood Excelon Double Din Nav Head Unit with CarPlay
• Back Up Camera W/ Night Vision
• JL Audio 13" Stealth Sub
• JL Component Speakers In Every Corner and Tweeters in Front A Pillars
• 4.10 Gearing with LSD rear open diff front
• Full traction coilover conversion with custom valved king 2.5s
• Warn manual locking hubs (no more vacuum actuated)
• manual idle control knob for cold weather warm ups and heavy winch operation
• Far from stock HD tie rod, drag link, track bar
• Brand new Spicer rebuildable/greaseable HD ball joints to be installed before sale
• Far from stock front diff cover with fox stabilizer
• Custom Alcan rear leaf packs and Firestone bags
• Icon 3.0 adjustable rear shocks
• Outlaw fab rear traction bars
• Black rhino 18x9.5 rims and spare
• Toyo open country RT 37x13.5 tires and spare (25k mi)
• tire rotations every oil change including the spare
• Fresh amsoil oil change performed
223k on odometer
• KDP mod
• ARP 625+ Studs
• Arb front bumper
