6th gear
NTt
Does anyone know if there is a possibility of putting a 6th gear or overdrive onto the gearbox of an FG64?
I am doing 2800 revs at 100K in 5th- just too high. Was 3000 revs before I put on the super singles.
Curtis in Texas
I've got a rebuilt Spicer 5831 3 speed brownie box with a .74 OD (IIRC) and a 2.0 under drive that's been taking up space in my shop.
It would work well for your application. Even have the drive shaft flanges for it. It shifts with a 3 speed aftermarket shifter like a Hurst!
Was going to use it in my FERD Class A Motorcoach but changed my mind and went with an Allison World 1000 5 speed behind the 5.9L Cummins I put in it.
PM me if you're interested and I'll shoot you some pictures and the spec sheet.
One of the nice parts of it is the under drive 1st gear for slow going.
Like pulling a boat out of the water. or maneuvering up a tight steep trail.
Woa, just noticed you are in Austrailia.
Shipping would be a killer.
But, I can still give you the specs and pictures if you want to consider looking for one closer. if you're interested.
pugslyyy
I was wondering that myself recently because I was reading the manual and saw that there is a 6th gear option for the transmission that goes in an extension housing.
boostin
I could be interested, but for the life of me can't figure out how to Send you a pm on my phone
Amesz00
If it's the same 6sp that's used in the bigger FE canters, then it's the same OD ratio, just a closer ratio box.
pugslyyy
Looks like a tiny bit taller in 6th but yeah pretty much.
DFWSFO
