7.3 DIESEL, 70K Orig Mis. SPECIAL VEHICLE, Motorhome/Amb./Rescue... registered as MH
adventuretrek
2003 FORD E-450
VIN: 99999999999
condition: like new
cylinders: 8 cylinders
drive: rwd
fuel: diesel
odometer: 70000
paint color: white
title status: clean
transmission: automatic
type: other
2003 FORD WHEELED COACH...AMBULANCE (fully equipped), DISASTER UNIT, CLINIC, RV MOTORHOME, SHOW DISPLAY - for Health shows etc.
Only 75,000 Orig miles, Interior and Exterior Excellent, NO RIPS, TEARS, DENTS, SCRAPES, RUST OR OTHER ISSUES!
MAINTENANCE. Note: this vehicle has had all the regular service done from day 1. A brief summary of the maintenance is as follows:
44,339 - A/C compressor and system renewed.... $1600.00 + freon
45,549- Brake Pads, and Rotors, seals replaced.....$1400.00
56,946 - Drive shaft replaced, radiator and coolant.....$800.00
58,981 - Ujoints replaced......$381.00
61,910 - Wiring and recharge AC........$500
62,090 - Batteries and tensioner replaced.......$1430.00
67,349 - Complete Service , Trans service, incl converter, differential change, Air Filt, Oil and Lub......$450.00
67,500 - Change valve stems to bronze so they can be easily checked. ..... $65.00
THIS UNIT HAS THE FOLLOWING EQUIPMENT
"LIGHTED" Outside Compartments , with ONE key that fits all ! Extra key also.
ALL DIAMOND PLATE TRIM, inside and out. - polished and restored in June, 2017.
LED LIGHTING - New Whelen LEDs installed where needed, including signal lights.
READ DIRECTIONAL OPTION, LED AMBER ARROWS.
FRONT AND REAR LIGHTBARS - Optional solid metal cover made to cover the front for non emergency use.
DUAL AIR CONDITIONERS - COLD AIR ..FRONT AND PATIENT COMPARTMENT - TEMP CONTROL IN REAR.
Cruise control, am/fm radio, 4 speed w/s wipers, new blades, 70 gal fuel tank. HD heater.
Special "Jake" 4 position braking....lighted control.
PATIENT COMPARTMENT REAR EXHAUST FAN, DOOR SCREENED WITH MAGNETIC SCREENING W/WINDOW.
OXYGEN, AND SUCTION IN PLACE.
REAR DOOR BETWEEN DRIVER AREA
OTHER INSTALLED OPTIONS ARE:
4000W INVERTER, EXTRA ACCESSORY PLUG FOR A/C
POWER OMNI DIRECTIONAL ANTENNA TV
LARGE SCREEN TV WITH SWIVEL BRACKET
4 EXTRA 12V ACCESSORY PLUGS, OVERHEAD COUNTER 12 FLOR. LIGHT
DOMETIC RV AWNING OVER RIGHT SIDE COOKING AREA
OUTSIDE FOOD KITCHEN WITH PROPANE STOVE, FOOD PREP AREA TOO.
DOMETIC FRIDGE AND FREEZER WITH REMOTE CONTROL AND MONITOR;
LG. CAP DOMETIC TOILET AND CANISTER TANK.
30 GAL FRESH WATER TANK, ATTACHED OUTSIDE HOSE, GREY WATER TANK
OUTSIDE SHOWER
INSIDE COFFEE MAKER, A/C INVERTER OR 110V.
MICROWAVE
LARGE TABLE APROX. 18" X 44"
DELUX CUSHIONED BENCH SEAT (PULL OUT FOR BED)
LOCKING FUEL CAPS
OVER $1000 WORTH OF SPARE PARTS (Filters, altinator starter, u jts, tensioner pulley, etc.)
FOR FURTHER INFO CONTACT NORM AT: 956 369.7575
haven
Forum rules require all ads in the For Sale section to include an asking price and the location where the vehicle may be seen. Please update your ad.
Deshet
Can you provide the details on the interver is it factory?
What does it power?
Is it 4000 peak watts or is that continuous?
adventuretrek
What does it power?
It is continuous, and connected to a 3 battery system on a pull out compartment. Usually the solar keeps the batteries charged. If you have any questions 9563697575
iStan814
