I have a 95 E350 7.3 that has been smoking some on colder start....by that I mean anytime the engine has not been run in 24hrs or so. It does go away when its hot out (70+) but smokes a decent amount of bluish smoke. Its burns the eyes pretty bad and smells a bit like fuel so I am apt to say its fuel, not oil being burned.
Its been doing this about a year or more. This past month I pulled the injectors and replaced all the o-rings, glow plugs, UCVH and VC gaskets, and ICP sensor, the old o-rings were intact but it was clear some oil was pooling on the bottom of the injectors as they had some residue built up.
I am still getting blue smoke in the same starting situations. Once it has run a couple minutes the smoke is completely gone and never returns until it sits again. Engine starts and runs great in any temperature. Passes contribution tests and buzz tests.
Thoughts on what could be causing this?
Bad injector?
IDM on its way out and causing timing issues?
Normal?
Turbo seals starting to let go....but zero smoke at temperature or load
I messed up an o-ring or didnt torque an injector correctly? Possible but I doubt it, wouldnt this be apparent all the time while running? I have about 400-500 miles on it since that repair. Smoke seems the exact same as before.
This thread is spot on, except I am 100% stock except for no cat and a walker BTM muffler.
http://powerstrokearmy.com/forums/showthread.php?t=31194&showall=1
Bad injector?
Normal?
