80 Series Driver Window Question..
adventureduo
Dave Druck [KI6LBB]
Ok, so the window flew down the other day at a 45 degree slant.
I finally got a second to get into the panel and check out whats going on and this is what i found.. the wheel has sheared off the pin on the arm.
Question of the day, (Searched and found nothing particular).. can you replace just the arm? or the entire arm and motor needs replacing? Or one step further, has anyone ever drilled out the wheel pin and made their own by milling out their own wheel?
Anyhow... any feedback would be appreciated. Seen them get shoved out of the track before but never this.
Mcoleman
