80 Series OEM Hand Throttle
Schattenjager
Anyone have one? If so, do you ever use it and hows the install? Know of any sources other than Slee (they are out of stock with an unknown resupply date)?
Tucan viajero
Just something to bear in mind:
¡Never pull on the hand throttle handle to increase the engine speed!
The plastic handle will break or separate from the cable in no time. If you have to increase the engine speed, step on the throttle pedal as needed, and once you have reached the desired rpm, carefully and gently pull the hand throttle until you feel the resistance increases, and turn clockwise to lock. This is the right way to do it in order to avoid breaking it.
Chuy
There is a supplier on IH8MUD importing them right now. I only had to wait two weeks to get mine and it was only $55! It installs super easy its just a pull cable with a locking knob. Its a very simple setup if your cruiser already has the pedal hardware, most of the late model cruisers have it, mine did. If you want to buy after market for only $15 check this out
http://www.copperstatecruisers.com/hand-throttle.html
Its not something I use everyday but I can remember the numerous times I sat in my cruiser reving the engine wishing I had something like this. Examples giving a jump start, running my OBA, running my winch, etc.
Mcoleman
