All-Terrain
No Road Required
How does the alignment change on an 80 when you lift it?
I understand the caster starts to decrease, so after about 2" of suspension lift, you need aftermarket bushings to return the caster angle to near stock.
What about the axles themselves, do they move left or right at all? Are there links to correct it, if so?
I want to keep alignment as close to factory as possible, but would like to get the truck lifted about 1-2". Starting with an 80 that already has the factory Landcruiser springs that were bought new and installed no more than 2 years ago, so it is at the true factory LC height already (no sagging).
