81 Ford Quadravan
Stitebunny
Hi guys. I was wondering what you think about the asking value on this van. What is something like this worth? I don't know anything about it other than what the ad says. I have a few things in the general price range he may want to trade for. I know these conversions can be hit or miss on the build quality. What are some specific things I should look for on this van if I went to check it out?
I'm looking for a 4x4 van mostly to use as a camper and access less crowded areas. Not really serious wheeling. Snow, sand, unimproved roads etc.
This seems like something that would fit that discription.
Thoughts?
Thanks a lot,
Chris
dsw4x4
Price seems to be in the ball park. I would drive it and see what it drives like. If handles or rides bad I would stay away from it because you could be chasing expensive gremlins with hard to find parts. Although I think quadvan (or some one) still sells all the bushings and stuff for these vans. Maybe someone that know for sure can chime in.
Derek
Stitebunny
Thanks for the reply and info. Am I correct in thinking that these conversions cannot be lifted at all?
adrenaline503
Hello,
Ive been in contact with the owner of the Quadravan, he seems like a nice guy who knows what he has and wants it to go to a good home. Bellow is an email he sent me with some more info:
"the van is a quadravan conversion by pathfinder.. basically you ordered a 4x4 van from the ford dealer, they sent it to pathfinder, then back to the dealer who delivered it to you . all regular truck parts used. Search online and you will find quite abit of stuff. I know almost nothing about this particular van...
I looked for over a year and ended up finding one in my town ( Maple Valley). I drove it a couple weeks, tried to sell my truck, didn't sell the truck, so the van just sat. My intentions were to build a 4x4 beach/dirtbike camper.
There's a big following of these vans, people drive them around the baja and stuff like that.
So, in the 2 1/2 years I've owned it, it has basically sat. I started it every 4-6 weeks and drive it on a 10 mile loop in my area 3 or 4 times a year. It last ran in October, last driven in July, So I started it today ( started on the first crank over) and drove it. Everything works fine. It has been parked in a covered area out of the weather.
The gas tanks have been full the entire time.... I checked the brakes when I bought it ( fine)and changed oil.... that's about it . I haven't put 100 miles on it since I've owned it.
The guy I bought it from ( I still have his number, he said call anytime) had the engine rebuilt and used it for a work van. He moved to Tuscon Arizona, didn't like the heat, and moved back. That is the majority of the miles on the new engine I believe. He said about 5000 miles since build. on the way back he blew a tire, and couldn't find a replacement that matched, so he put 2 tires on the front which are a different size than the rear...obviously not good for a 4 wheel drive. He said he didn't put in 4 wheel drive since. he said it all works fine. I took it out in the snow once just for fun, put it in 4 high, locked the hubs and it definitely worked... I did that for about 100 yards, thats all I can tell you about the 4 wheel drive.
The body is in great shape for a 30 year old rig. a little rust, but not much. looks to have been repainted. some bondo. Not bent, panels all good, not rusting out.
The dash is great, everything works, the 2 captains chairs aren't that great.
Only a couple issues... speedo drive gear (about $20) is out,so no speedo or odo, ignition turns without key, but door locks work. actually thats about it.
Everytime I drive it I really would like to keep it and build, but life has changed. They are hard to find, and usually very expensive. For the kind of shape its in, I'm a few thou under priced and taking it in the shorts, but I need the space.
The guy I got it from was using it as an everyday work truck. cargo area is carpeted and in good shape.
I planned to use it as a work truck and slowly build it, but things changed.
Could you drive it across the country? I would go thru it closely , but the guy drove it to Tuscon and back the way it is.
If I was going to keep it, the first thing I would do is put a set of tires on it. Thats about all it really needs.
Don't know much about the gearing, but it seems geared low for an auto.... on the freeway it was fine, but certainly doesn't have an overdrive transmission....
That's about all I can think of... Has a full size spare ( the size of the rears) so you could look for a used tire to match and be into 4 wheel drive right away.
let me know if you are interested,
If you have questions let me know, I'll do my best to answer them."
He can reached directly at pacificnwdiving@comcast.net
New River KTM
Quadravan Parts
All of the Quadravan parts can be found here. Gordon is a good guy and provides all the replacement parts under license. Some good tech info also.
http://www.pathfinder-vans.com/index.html
These vans can be lifted just depends on how high you want to go. My 89 E-250 just got a complete Lift of about 2" over stock using Superlift Springs and rear spacer blocks (but a re-arched spring would be better). Pathfinder provided all the new bushings at the same time I replaced much of the stock hardware with new grade 8 stuff and brakes and lines all got replaced. All the Ford parts are available pretty reasonable at most parts stores.
Different tire sizes are a big no no so tend to that quickly. As for price sounds about right rust level would be my biggest concern.
Good Luck
Stitebunny
Thanks a lot guys.
Adrenaline, are you thinking about buying/trading for the van? Have you seen it in person or driven it?
I'm really on the fence about trading what I have for it. I don't want to go check it out and waste his time if I'm not ready to do it for sure.
I guess if I wait too long though someone might beat me to it!
adrenaline503
As much as I would love that van, and trust me, I would love it, I just don't have the means to get it right now. I would have to sell my Frontier, and while I'm not opposed to that idea now might not be the time. Plus I don't have a garage so getting it to baseline this time of year would be miserable. I havent seen it or driven it, I don't want to waste his time. Bummer though, get an ambulance top and I'd be thrilled.
Stitebunny
Well I decided to commit to a trade offer only to find out there are several people taking cash offers to the owner. It sounds like it will go to the highest bidder. Take a suit case full if you want to be sure it becomes yours!
adrenaline503
Figures. That was a good deal and im not shocked. At least I can stop thinking about it.
Stitebunny
I was a bit dissappointed to hear that. But like I said, I was on the fence anyway. I'll live!
He made it sound like it could be some people from here. So maybe we will get to see the van anyway!
And lesson learned. Don't post links to ad's of something you may want before you decide!
adrenaline503
Yea, that's true. Ask for advice and someone might snipe it for you. Such is life, it's rarely fair.
Chonker LMTV
