82 FJ60 H55F "Expedition Built" SOLD!
82bruizer
Also posted on IH8MUD
SOLD
Overview
82 FJ60 original engine 191,xxx miles, H55F 5 speed, 4.11 gears, OME lift kit, GOBI Safari Rack (Ranger), Axe/shovel and Hi-Lift locking rack mounts, 4 Delta rack driving lights, ARB locked in the rear, onboard ARB air for tires, Goodyear duratracks 285/75/16, National Luna dual battery controller, dual Optima yellowtop batteries, MeanGreen 200Amp alternator, Smittybuilt 12k winch, custom bumpers front and rear (bolted), custom sliders (welded), Alpine CD-MP3 controller stereo, Alpine PDX5M Marine grade 5ch 600 watt amplifier, Alpine 6” in doors and 6x9 in rear cargo area, 10” Memphis Audio Subwoofer, professional grade 2GA aux circuit for AMP, Radios, Fridge, lights and other accessories.
Engine:
Original engine 191,xxx miles, runs strong, original carb rebuilt by Jim C. two years ago (secondary’s are nice). All smog equipment intact and operational. Radiator replaced last year. New OEM starter installed last year.
Drivetrain:
New H55F 5 speed installed last year. New Clutch (Marlin), Transfer case fully rebuilt. Front diff rebuilt with all new bearings. Drivelines adjusted and rebalanced. Rear axle fully rebuilt end to end with ARB locker 4 years ago. Front knuckles fully rebuilt 5 years ago with all new bearings, races, and seals. Tires and Rims installed by Discount Tire in 2010 have three certificates for replacement left, all tires show little wear less than 10k on them.
Body/Interior:
2008 – Body completely prepped with all glass removed (was planning on changing color), all rust cut out and replaced with metal, and repainted to factory white color. Minor rock rash on driver side Interior is in great shape. Two small cracks in dash board. Interior 9/10 except for cargo carpet. Quarter sized spidercrack in windshield, sealed for 4 years now no issues and not in line of sight for driver.
Armor:
Custom bumpers front and back (bolted on) sliders are welded for max strength. Smitybuilt 12K winch custom mounted to frame under front bumper.
Expedition gear:
Dual battery setup (National Luna controller and display), Dual Yellowtop Optimas (2008 and 2012), Meangreen 200A alternator, Midland 520xl pro CB radio and through the roof custom antenna mount.
I purchased this cruiser in 2007 as the third owner and have extensive receipts dating back to when the second owner purchased this truck in 1988, including a log of every gastank fill up with MPGs etc. I didn’t keep that part up, but did keep up the receipts. The H55F, transfer splitcase rebuild, new clutch, front third rebuild, new radiator, valve adjustment were all done September of last year 2012 by Robbie Antonson (Adventure Offroad), Robbie is the tech editor for Toyota trails and best in the business land cruiser whisperer, it doesn’t get better than that. He went through the entire truck.
This truck has been great to me and I would drive it from coast to coast without hesitation. It saddens me to sell but priorities have changed in life. I will build another in the future.
cruiseroutfit
Wow, didn't see this coming. I've spent a handful of days out on the trail with this 60, a fantastic rig! Here is to hoping it finds a good home, I'll be spreading the word around these parts.
82bruizer
Thanks! The suspension is OME heavy lift springs with greasable shackles. Yes the A/C works well, it is still the old R12 in there (if it works, dont fix it).
82bruizer
Very tempting. Any leaks?
It will mark its spot with a couple of drops of oil when parked, literally a couple of drops. I had the mechanic look into it and it is either the front lip of the oil pan or front main seal. it is very minor. Nothing on the rear of engine or transmission, rear main was replaced last year when new transmission was installed and transfer was rebuilt.
Houie
