'85 Toyota FJ60 SOA/ Vortec/ ARB/ Rack/ Awning Etc. SoCal
devortex
SOLD
85 with very nice body and frame
Smog legal Vortec 5.7 (complete smog cert with permanent BAR sticker)
4L60E auto trans
SOA with tall shock hoops in the front (will fit 37" tires easily)
Upgraded front rotors
Hella headlamps with upgraded harness
Cold A/C - Hot Heat
ARB front bumper and side steps
Custom dual swing rear bumper
ConFerr rack
ARB awning
Locking center console
Hella map light
IPF driving lamps
CB with Fire Stik antenna and splitter
Hideaway CD player
6 new 33-10.50R15 BF Goodrich A/Ts
Nice interior
New windshield
Safari Snorkel plumbed to GM airbox
Mile Marker 9000 winch
This is an awesome FJ60. Very strong, very durable. Looks great but is not a trailer queen. Biggest things that need attention at some point:
Fuel spider needs replacing. A couple of the poppets stick alternately open or closed causing a rich or lean condition depending on when they stick. Sometimes it won't do it for a week, other times it'll do it everyday for a while. I just haven't had the time to replace the spider with the new, non-poppet style.
Front axle has developed a vibration when 4 is engaged. Haven't looked into this yet. I do have a good complete axle that can be included to use for parts if necessary.
Winch is currently not wired up. Was in the process of mounting a second battery but not completed.
There are a few tiny bubbles on the rear roof that need attention before it spreads. I think there was a little bit of repair done above the passenger door prior to my ownership.
Please ask questions and I'll try to address anything you need to know. I was figuring this is a $12K rig but considering the repairs I noted, I'd take $10K for it as is. Clear title, in my name, current tags.
Located in Devore, California...about 75 miles from Los Angeles. DSCN0032.JPGDSCN0035.JPGDSCN0034.JPGDSCN0033.JPGDSCN0031.JPG
Viggen
Just here...
Nice looking rig. "Front axle has developed a vibration when 4 is engaged"- did you do a cut and turn/ correct pinion angle with your SOA?
devortex
Yes, cut and turn was done when the SOA was originally completed. I haven't taken the time to sort out the new vibration that recently developed.
devortex
Additional photos
2 E L O
Absolutely killer truck. California is so far away! Oy...
Sent from my HTC Evo 4g using Tapatalk
iStan814
