88 Econoline best setup for 4x4 conversion ....
BigDan
As the title says ,
I have an 88 Éconoline E-250 with 351W & C6 .....
I want to convert it to 4x4 ......
before I start ,may as well ask here what should I look for ....
Ill try to get a complete F-250 with 351W & E4OD ( I was told only one that would do the job ) ......
I want free hubs , solid axles , rear disc brakes would be a nice touch but not a priority ....
It has to fit width wise too !
thanks
Dan ,
TheViking
I would keep the C6 as overdrive won't be much use on the back roads and trails. The C6 is viewed as a hog for loss of power at the wheel but it's a stout unit.
The process should be about the same I imagine as a solid axle swap on a Ford truck. Google it.
VANMAN
I have a Danna 44HD which would be perfect under your truck....Quigley 4 link...bolt on...replace bushings with polyurethane...I'll let it go cheap to someone who will use it....its in Reno NV...shipping isnt that bad....
VANMAN
I still have it...come and get it!! will give a good deal and IS THE easiest and cheapest way to convert to 4x4...axle never gave me any problems!
Paddy
Fastenal can ship this for cheap for you guys. It's called their third party logistics dept.
BigDan
been a long time ,
what about a 5.9L 6BT + auto tranny + T/case
I can get a low mileage 4x4 92 cummins Ram 2500 complete .........
I think it could make a good swap ...
BigDan
wow ,,,thanks a lot !
really apreciated ....
have you been able to quiet down the Cummins cabin noise ?
Dan
Rocksrus
Do u still have it is it coil spring
jesus m anderson
