9.5" Ring , 4.27 Ratio Rear Axle With Disc Brakes, ~60" Wide,
snare
This could make a great axle for a build.
Beefy 9.5" Ring Gear
31 spline axle shafts
Came with Disc Brakes, with integrated Emergency Brake (Discs and Calipers Not included)
4.27 gear ratio
Removable Third Member Design.
Approximately 60" wide.
Comes with Panhard Bar, Trailing Arms, rear brake cables.
This is from a coil sprung rear 97-99 Mitsubishi Montero.
These rear axles are not known to break. They are surprisingly beefy and just keep going.
For some reason the forum isnt letting me upload pics right now. I will try again later.
Also feel free to email me at caurelius1@gmail.com and I can send you pics. (please identify that you are from ExPo).
$200 for the axle assembly.
Local Pick Up for the axle assembly.
banshee01
