90,000 mile service for 1998 Taco - parts list
crawler#976
My truck was due for the recommended 90,000 mile service. The parts listed below will complete the following service:
R&R waterpump, timing belt and tensioner.
Replace Camshaft and Crankshaft seals.
Replace all hoses and belts (less water heater)
All numbers are for OEM Toyota parts.
________________
Ac belt - 3.4 liter - 3.4 liter
99364-20870-78
P/S belt - 3.4 liter 1998 - 2004
90080-91126-83
Alternator belt - 3.4 liter - 3.4 liter
90080-91090-83
Upper hose - 3.4 liter - 3.4 liter
16571-62070
Lower hose, 4wd, Auto trans - 3.4 liter - 3.4 liter
16572-07040
Water pump assy, 4wd, 4wd - 3.4 liter - 3.4 liter
16100-69398-33
Thermostat - 3.4 liter
90916-03075
Gasket – Water Inlet - 3.4 liter 2000 - 2004
16325-62010
TENSIONER ASSY, Timing
13540-62021
Timing belt - 3.4 liter 1995 - 1998
13568-69095
Camshaft seal, all models - 3.4l 1995 - 2004 (need two)
90311-38051
SEAL, TYPE T OIL (Crankshaft Seal)
90311-40022
Toyota FIPG Sealer - 3.4 liter 1995 - 1998
00295-00103
______________
The water pump was leaking when removed, the timing belt was showing signs of wear, and the left side cam seal was damp, so I'd say Toyota has the service interval called pretty darn close.
Total labor was: 3 hours for timing belt, 1 hour for water pump, 1 hour for cam and crank seals.
Mark
Goldenbora
