90k Tune up
I have searched for a good thread containing all the info needed for the 90k Tune up and I could not find much. So tell me.... what do you guys recommend doing at 90k?, Where is the best place (cheapest) to buy the parts necessary? let me know whatcha think
Taken from http://smg.toyotapartsandservice.com/guides.php
  • Replace engine oil and oil filter
  • Replace engine air filter
  • Replace engine coolant
  • Lubricate propeller shaft (4WD)
  • Lubricate wheel Bearings (2WD)
  • Replace non-platinum spark plugs
  • replace timing belt (5VZ-FE)
  • Re-torque propeller shaft bolt
  • Rotate tires
Inspect the following
  • Automatic transmission fluid
  • Ball joints and dust covers
  • brake lines and hoses
  • brake lining/drums and brake pads/discs
  • Drive Belts
  • Drive shaft boots (4WD)
  • Exhaust pipes and mountings
  • Front differential oil (4WD)
  • Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
  • Fuel tank cap gasket
  • Manual transmission oil
  • Radiator, condenser and/or intercooler
  • Rear Differential oil
  • Steering gear box
  • Steering linkage and boots
  • Transfer case oil (4WD)
Additional Maintenance Items for Special Operating Conditions:
Driving on Rough, Muddy or Snow-Melted Roads
  • Inspect nuts and bolts on chassis and body
Towing a Trailer or using a Camper or Car-Top Carrier
  • Replace automatic transmission fluid (2WD with A44D)
  • Replace front differential oil (4WD)
  • Replace manual transmission oil
  • Replace rear differential oil, including limited-slip
  • Replace transfer case oil (4WD)
Add to above (if I didn't miss it):
Flush brake fluid and power steering fluid.
Contact dealer and run VIN for recalls and service bulletins.
Starter contacts and alternator brushes seem to be popular PM items.
Inspect front wheel bearings, especially for noise (assuming non-locking hubs using a "case" bearing).
Use Toyota coolant, with distilled water.
Check rear axle seals and under the wheel cylinder dust boots while you are inspecting the rear brakes.
Many people replace all the coolant hoses at 90K, especially on the V6 since the timing belt and water pump will already be out. You will have to do them eventually, now is probably a good time.
I did not look to see if your spare is in stock location, but if it is, service the winch.
Consider replacing the O2 sensors in the near future, especially as gas goes up. It may help your cats last longer, too.
If your battery is original, start shopping...
Professionally detail or have the truck detailed...you will feel better about spending all the time and money on the 90K service. :yikes:
Regarding where to buy, Toyota of Dallas has had a good rep, AFAIK. I think they have a 25% discount from list. After dealing with my local dealer, I'd seriously consider an on-line source first.
Bobbyjr
